i thought i would put up a post on here to help you keep the R8 looking at its best. this will help you from keeping your R8 free from swirls
a pic of swirls
this is caused bad bad washing
and this is how it should look like
ok then
first off you need 2 buckets for this
soap in one bucket and just water in the other
a good wash mittlike this one for the bodywork
and a microfibre wash mitt for the wheels like this one
to foam the car you need a foam lance like this one
a good Pressure washer like this one
http://www.karcher.co.uk/product.php?pr=90
and some water![]()
first off is to clean the wheels for the R8 i find the wheels are good for cleaning as it as ample space to get into the inside without using a brush so i use a microfibre was mitt for this job on a R8
so with the foam lance and using a citrus cleaner spray the wheels then using the microfibre was mitt to clean the wheel and rinse the wash mitt very often
before
after
once the wheels are clean time for the body work
again with foam lance spray the citrus in at the wheel arches, front bumber along the side pannels and around the raer of the car then spray the rest of the car
the R8 with citrus through the foam lance
for the next step is the foam through the foam lance
with the foam spray from the top down
the R8 with the foam on for 5 mins
after 5 mins rinse the foam off the car with the karcher
so the next step is to wash the R8 with the 2 buckets and a lambs wool mitt.
put the wash mitt in the soapy bucket and start on the roof of the R8 and only do a small section at a time, then rinse the mitt in the clear water before putting the wash mitt back into the soapy water, this way your not putting any dirt back onto the R8 and inflicting any damage to the fine paint work, when washing you always work from top to bottom and in straight lines
so the R8 is now wash and its time to dry it off
i`m using a leaf blower here
this is the way i like to dry the R8 off as your not touching the paint work but you can use drying towels like this one
i hope this will help you on cleaning the car but feel free to ask any Q`s
mike
LinkBack URL
About LinkBacks
Reply
Sold Aug 09
