Here is a write up on one of my childhood fantasies, the Acura NSX.
Basically a polishing job with a little but not so little interior job (no shampooing of the carpet cause the owner wanted to do it himself).
Now excuse the weird picture gaps inbetween processes because me being a big excited idiot forgot to charge my camera battery so I was working off of 1 bar of life then doing a quick charge to take pics then back to charging. I know it's bad for the battery but it will never happen again I promise plus I believe I remember reading somewhere I can charge the battery anytime, but I rather not risk it anyway.
So here we go, not very educational but hopefully you can catch some tips, product reviews, or just enjoy the show. Also the owner had just recently purchased this NSX so some of the neglect you are about to see is not his fault.
The Japanese Legend
The swirls, spider webbing, etc
I honestly don't think it had ever been polished in it's life.
So now on to the routine starting with the wheels
Soaking with p21s wheel gel cleaner
Then on to the engine with some basic before and afters
before
after
some more afters but taken at a later time
Onto the washing
After rinsing the car down you could see in certain parts that the water was sheeting, which is a sign of no protection(wax, sealant).
Two bucket method
Sea Sponge
Dried off with the waffle weave towel which is way better then a chamois because of the speed, softness, etc
Started claying with Riccardo Clay and clay lube being Meguiars Last Touch cut 50/50 with water.
After just the roof
Rinsed off the car then dried it off again with the waffle weave towel
Measured the paint in microns to look for any low spots and if anything was repainted
It turns out the two rear quarter panels were repainted(generally OEM is around 100-130 microns in my experience)
And I guess the trunk blended in
But the rest of the car was pretty much OEM
Masked up the car which is very important. I'm not finished in this pic though by the way.
Started polishing with the rotary and Presta Chroma Polish, 5.5 inch Orange Lake Country pad, and the Makita.
Technique being the Zenith Point Technique.
Spreading at 900 RPM
Breaking down at 1200 RPM
And polishing until clear at 1500 RPM
Then back down the scale to 1200RPM
Then finishing at 1000 RPM
Here is the hood polished but the headlight not
A 50/50 shot
A bigger view
Driver's side finished
Passengers side to go
Just wanted to throw in this pic cause I though it looked cool. Notice how many orange pads I got out. I learned that a brand new clean pad cuts better then just brushing it off, so I generally use at least a new pad per panel sometimes even two.
So anyways with the cutting stage done I washed off the car with Hi Temp Prep wash and a very soft Lambs Wool Mitt. The Prep Wash is great for eating up the polishing dust and oils and makes the caked up parts easier to remove.
Now rinsed that off and dried up. Started the refining/burnishing polish with a new product and pad to try out which was 3M Ultrafina and the 3M Blue Pad on the Rotary with the 3M Gray Foam Backing Plate which is a softer foam then the yellow which is great for finishing.
Personally I like the Ultrafina better then Menzerna P085RD because it is so much easier to wipe off and is great to work with on the Rotary. Some people have said that PO85RD leaves a better finish and I have both so I will do a comparison but the Ultrafina finish is AMAZING.
Poorboys Wheel Sealant on the rims, honestly I have been hearing about people just putting on Zaino Z2 on the rims so after I'm done with my PB I'm gonna give that a shot cause that sounds pretty cool.
I also did Black Wow on the rubber trims. Here is a 50/50
LinkBack URL
About LinkBacks
Reply
8,Paddles,Mag ride,Jet-Blue/Carbon blades,Smoke chrome OEM 5 spokes & Lambo S.L. whls,Miltek exh.PPI Steering whl,rear wing,front grill,air filter kit.C.F.interior trim,V10 sideskirts,premium black leather,B&O,navi,camara. KEEPURSHINEYSIDEUP/STICKYSIDEDOWN VIDEO:R8 in CANYON video ... janerinsurance.com/r8 ...\"/
