Pressure Washer: Too much pressure?
Results 1 to 4 of 4
Thread: Pressure Washer: Too much pressure?
    Jul 2008
    Dubai, UAE
    I know a number of people seem to recommend pressure washers/foam lances during car cleaning. I was wondering how much pressure / at what distance is best. And is the only advantage quickness, since I'm a bit worried about the pressure causing damage to the paint. The lowest pressure machine I could locate was '100 bar max' and a maximum water flow of 340 liters per hour. Any danger with a machine like that?
    09 V8 R8, Jet Blue/Carbon blades, CF mirrors, R-Tronic, all CF options, black interior with Victoria Blue stitching
    Exclamation Re: Pressure Washer: Too much pressure?
    With a little distance between your wand and the paint ,you should be safe. A deep chip blasted directly could strip car of paint. Scary thought. Find a soap hook up and using low setting you almost have the touchless wash/soap system the Pro.s use.
    GONE-BUT NEVER FORGOTTEN '8,Paddles,Mag ride,Jet-Blue/Carbon blades,Smoke chrome OEM 5 spokes & Lambo S.L. whls,Miltek exh.PPI Steering whl,rear wing,front grill,air filter kit.C.F.interior trim,V10 sideskirts,premium black leather,B&O,navi,camara. KEEPURSHINEYSIDEUP/STICKYSIDEDOWN VIDEO:R8 in CANYON video ... janerinsurance.com/r8 ...\"/
    U.K.
    Keep any pressure washer a good couple of feet away from tyre side walls too.
    Regards, Graham.
    Jul 2008
    Dubai, UAE
    Alright thanks a lot guys, I think I'll test it at a good distance on something other than the R8 to start with just to get a feel of how much pressure is involved
  6. Remove Advertisements
  1. correct tire pressure for Pirelli PZero's?
    By homewood in forum Wheel and Tire Discussion
    Last Post: 10-21-2011, 11:44 AM
  2. tire pressure for track tires?
    By silver in forum Wheel and Tire Discussion
    Last Post: 11-20-2010, 02:55 PM
  3. Retrofit: V10 Clutch & Pressure Plate
    By OEMplus.com in forum OEMplus
    Last Post: 05-26-2010, 10:33 AM
  4. Tire pressure light question
    Last Post: 01-21-2010, 10:33 AM
  5. Tyre Pressure setting
    By MikeB in forum Wheel and Tire Discussion
    Last Post: 09-21-2009, 09:59 PM
