Cleaning The Windshield
Results 1 to 10 of 10
Thread: Cleaning The Windshield
    Senior Member R8Spyderman's Avatar
    Dec 2010
    Sanibel, FL and Woodstock, VT
    After 5+ months of ownership and many hand washings, I just this week discovered that I don't need to pop the boot lid so as to lift the wipers to get at the windscreen under them. So, for the benefit of slow learners like me and new owners, all you need to do is lift the wiper blade toward the top of the windscreen and they will move maybe 30 degrees and then you can lift them up and out of the way. Simply lay them down again and push them back to their resting position afterward. If it took me nearly half a year to figure this out I'm guessing it will come as a surprise to at least a few of you so I thought it worth sharing.
    Sep 2010
    Chicagoland area
    Re: Cleaning The Windshield
    Lmao!
    Dec 2010
    "Am I a clown? Do I amuse you? "
    — Joe Pesci
    Sep 2010
    Chicagoland area
    Why yes Sir, yes you do.
    Dec 2010
    Sep 2010
    Chicagoland area
    Just call me MR. Negative from now on, buddy....
    Dec 2010
    Quote Originally Posted by NVRL8R8 View Post
    Senior Member Rit2's Avatar
    Malaysia
    Quote Originally Posted by R8Spyderman View Post
    ... all you need to do is lift the wiper blade toward the top of the windscreen and they will move maybe 30 degrees and then you can lift them up and out of the way ...
    That would cause damage over time Use the windshield wiper lever RESET/ROCKER switches to set the wiper service position, as described in the Owner's Manual. However, the easiest method to clean and dry the area at the wiper park position is still to raise that front luggage lid (which invariably happens as you need to dry that water under the lid )
    Regards
    Dec 2010
    Quote Originally Posted by Rit2 View Post
    Regards
    I totally disagree. The wiper arms move freely to the so-called service position. I don't force it, it moves quite freely into that position and back to the park position. No resistance whatsoever, so how it will cause wear is beyond me. If by "easiest" you mean "hardest", then do it your way but now that I don't have to bother popping the lid every time I clean my windshield, I'm doing it this way from now on. Nowhere in the owner's manual does it warn not to do this. I don't clean my windshield only when I wash my car, I clean it almost every couple of days, but when I wash my car and pop the lids to dry under them, I don't need to move the wipers but that's only once a week or so. Chacun à son goût.
    Regards back at ya!
    Malaysia
    The Audi wiper service position procedure is a bit inconvenient. Alternatively, we could switch-on the ignition, move the wipers ELECTRICALLY, switch-off the ignition when the wiper has moved a few inches, and you now have access to the park position.
    Yes you are right. To each his/her own preference, whether it's right or wrong, and eventually, you will reap the result(s) of your own effort
    Regards.
  1. Rinseless Process of Cleaning R8?
    By nexlogic in forum Detailing & Car Care
    Last Post: 08-22-2011, 08:47 AM
  2. alcantara cleaning/ and question abt new delievery
    By 8rr8 in forum General Discussion
    Last Post: 08-04-2011, 08:48 AM
  3. R8 Cleaning
    By nile in forum Detailing & Car Care
    Last Post: 10-05-2008, 03:07 AM
  4. More cleaning
    By Andyuk911 in forum General Discussion
    Last Post: 10-09-2007, 02:46 PM
  5. Cleaning an R8
    Last Post: 09-07-2007, 04:26 PM
