Over the course of the last 14 months we have gained a strong knowledge of how the R8 works and with this in mind we have launched a range of upgrades to enhance ownership and drivability of the car.
Taken from our website, here are a range of the upgrades we offer:-
Brake Upgrades:-
Stage 1
Stage 1 brake upgrade consists of Pagid RS4-2 Blue pad. Ideal for fast road use. Including front and rear replacement. Specific pad details:
- Friction Level Cold: 0.40
- At 100 degrees centigrade: 0.42
- At 300 degrees centigrade: 0.43
- Max at: 0.46 @550 degrees centigrade
- Constant working temperature: 350-600degrees centigrade
- Max temperature for short period only: 650 degrees centigrade
Stage 2
Stage 2 brake upgrade consists of ceramic based Pagid RS-29 track pad. Suitable only for track use. Including front and rear replacement: Specific pad details:-
- At 100 degrees centigrade: 0.43
- At 300 degrees centigrade: 0.47
- Max at: 0.49 @550 degrees centigrade
- Constant working temperature: 400-700degrees centigrade
- Max temperature for short period only: 750 degrees centigrade
Stage 3
Replaces standard front disc with 34mmx380mm dia. two piece disc. Uses standard calliper and revised brackets. Front only. Also available with slotted disc. Includes brake fluid upgrade.
Brake fluid upgrade
Brake fluid upgrade using Motul RBF600 fluid. A real must for serious drivers. Specific fluid details:
- Dry boiling point of 312 degrees centigrade
- Wet boiling point of 316 degrees centigrade
Suspension Upgrade:-
Stage 1
Sport spring kit working with standard damping. Reducing ride height by approximately 15mm on the front and 30mm on the rear. Fitting includes four wheel laser alignment using our VAG main dealer spec system.
Stage 2
Sport damper and spring kit allowing height adjustment of the front and rear beyond stage 1. Suitable for road and track use. Fitting includes four wheel laser alignment using our VAG main dealer spec system.
Four wheel alignment option to Re-adjustment the suspension geometry for track day use only.
