Wheel Spacers
Results 1 to 8 of 8
Thread: Wheel Spacers
    Feb 2009
    Wheel Spacers
    Has anyone tried installing 20MM or other size wheel spacer for stock wheels on rear of car? Any problems or things to know about?
    Senior Member R84ME's Avatar
    Aug 2008
    Arizona, USA
    Re: Wheel Spacers
    HARRISON's your man.
    Re: Wheel Spacers
    You could probably run 20 mm but you will be constricted to a no larger tire size. More rubber is a little better than less.10 mm spacers, and I still use 235 and 315 with NO problems. wider rear wheels can easily be run on the rear if the added width is to the inside of wheel wells. \"/
    GONE-BUT NEVER FORGOTTEN '8,Paddles,Mag ride,Jet-Blue/Carbon blades,Smoke chrome OEM 5 spokes & Lambo S.L. whls,Miltek exh.PPI Steering whl,rear wing,front grill,air filter kit.C.F.interior trim,V10 sideskirts,premium black leather,B&O,navi,camara. KEEPURSHINEYSIDEUP/STICKYSIDEDOWN VIDEO:R8 in CANYON video ... janerinsurance.com/r8 ...\"/
    Feb 2009
    Re: Wheel Spacers
    Harrison:
    So you think I can use the 20MM w/the stock wheels and tires?
    Jan 2010
    Guernsey, A Tax Haven
    Re: Wheel Spacers
    Harrisons wording above would suggest the answer is yes you can.
    Feb 2009
    Re: Wheel Spacers
    Ok. Thanks much.
    May 2008
    Motor City
    Re: Wheel Spacers
    You could probably run 20 mm but you will be constricted to a no larger tire size. More rubber is a little better than less.10 mm spacers, and I still use 235 and 315 with NO problems. wider rear wheels can easily be run on the rear if the added width is to the inside of wheel wells. "/
    Where you running the spacers when you cracked the spoke
    Re: Wheel Spacers
    Yes, spacers used when 4 spokes broke. Chroming may have been a factor. Audi kept my broken wheel . I wanted to make a coffee table out of that broken 11x 19.
  10. Remove Advertisements
  1. R8 with spacers
    By martin1234 in forum General Discussion
    Last Post: 06-22-2011, 07:27 PM
  2. Wheel Spacers for HRE wheels
    By CALBenzo in forum Wheel and Tire Discussion
    Last Post: 05-02-2011, 09:26 PM
  3. 15mm Spacers
    By CALBenzo in forum Appearance / Body Modifications
    Last Post: 02-06-2011, 04:14 PM
  4. R8 Wheel Spacers - Recommendations?
    By danko in forum Wheel and Tire Discussion
    Last Post: 06-08-2010, 12:08 PM
