I have seen threads here and on a few other boards and wanted to centralize some of the data that I have gathered together for 2008 & 2009 owners who might be coveting the updated 2010 RNS-E system.
For those not entirely clear on the details, there is an excellent Fourtitude writeup that summarizes the system.
For a 100% OEM retrofit, you will need a 2010 RNS-E system and the corresponding Rear View Camera Controller. We provide both of these as a retrofit kit, inclusive of detailed instructions.
I realize that we can't control every potential buyer in the world, so here is the install in a nutshell:
- Using radio keys, remove and replace the head unit. Make sure you eject the navigation disc first...
- Remove the rear parcel shelf. Two 9mm bolts near the center-line of the vehicle will allow the entire cover to lift off. There are four "feet" at the base of the cover which sit inside rubber suction cups when in place. You'll need to wiggle a bit to release these.
- The RVC module (on LHD & RHD vehicles) is the module closest to the left door. There are three 10mm nuts that secure the bracket to the firewall.
- Once the bracket is off, the module can be exchanged easily. The connector is the same for both, so no modifications are required.
- As usual, installation is the reverse of removal. Make sure the parcel shelf is properly seated to avoid damage to the vehicle and blocked access to the CD-Changer or AMI unit.
The coding needs to be updated for two modules.
- Central Convenience (module 09) needs to have the optical parking disabled.
- RVC (module 6C) needs to be recoded as follows:
- Software: 1000412
- Workshop: 02197
- Importer: 785
- Equip No: 00200
On our test cars, these values are the same for '08 V8 and '10 V10. I don't recall if moving the RVC module from car to car wiped these out, but the car had to be programmed to add the guidance lines back in after the swap.
As mentioned above, we have this package available on our website here: RNS-E Navigation Retrofit: 2010
Next up: AMI Retrofit!
LinkBack URL
About LinkBacks
Reply
2009 Audi R8
2010 Audi S5
American Muscle
Audi Tourist Trophy
R8 GT
STāSIS R8
The Shoe
Yawning Maw
