Brembo GT kit for R8!
Results 1 to 6 of 6
Thread: Brembo GT kit for R8!
    Aug 2008
    Brembo now has the Gran Turismo kit for the R8! Kit is only for the front, and its very simple. It has 2 oversize rotors, used with the stock Brembo 8 piston calipers.
    Aug 2008
    Re: Brembo GT kit for R8!
    How much ?
    Any problems with standard ones on the track ?
    Aug 2008
    Im not sure about track use with stockers, but the upgraded ones would have less fade. Theyre $2195. Ive never driven an R8 so Im not sure if the car would need the upgrade, but for tracking the car, Im sure the upgrade would be worth it.
    May 2008
    Less fade? Doubtful, very doubtful.
    The stock OEM HUGE calipers are all you will ever need - you should get improved pads specifically for track use as well as 'upgrade' the brake fluid to Motul RBF600.
    This is all you will ever need.......
    Aug 2008
    The stock rotors are all you will ever need. Pair them with some good track pads and you will have better braking than just about any car out there. I switched to Pagid Yellows after wearing out my stock pads after seven track days. The yellows are incredible and do not wear the rotors out quickly. After another 5 days on the track (12 total) my rotors measure R/R 31.47 MM L/R 31.63 MM New 32MM min spec 30.4. L/F 33.5MM R/F 33.66MM new 34MM front Min spec 32.4. I brake very hard and have never expereicne anything like the R8 brakes. Had to also switch fluid to motul RBF 600 to keep from boiling.
    http://www.youtube.com/watch?v=ifX1ib_yHhI
    http://www.youtube.com/watch?v=JLmdgyI3PuQ
    May 2008
    That is exactly what I've found over the years and about 2,000 sets of Yellows -
    I try to sound objective - and my advice indeed is - but it truly takes 'unbiased reports' of actual use to show the absolute truth
    I would, without a doubt, have Pagid Yellows for track days and switch to OEM for street use.
    P.S. The video quality of your track session is SUPERB!
    __________________
    Now carrying Pagid RS29 TRACK brake pads for your R8
    Same pad compound that won 24 hrs of Daytona, LeMans ......
    Also carry RS42 Pagid Blues
    www.Rennstore.com 425-765-1090
  8. Remove Advertisements
  1. Brembo brake rotors?
    By AL3ayali_Dubai in forum General Discussion
    Last Post: 10-24-2011, 11:20 AM
  2. Brembo Big Brake Upgrade
    By YUL_R8_V10 in forum Wheel and Tire Discussion
    Last Post: 04-21-2011, 12:47 PM
  3. Anyone do the Brembo brake upgrade?
    By Maverick in forum Wheel and Tire Discussion
    Last Post: 04-08-2010, 01:14 PM
  4. Replies: 4
    Last Post: 09-01-2009, 09:47 AM
  5. Brembo Brake Kit
    By Exotica-Motorsports in forum Wheel and Tire Discussion
    Last Post: 05-29-2008, 10:18 AM
