Wheel Alignment for Track Use
Results 1 to 10 of 12
Thread: Wheel Alignment for Track Use
    Apr 2008
    USA
    After 3 two-day track events, I wore my left front tire's outside shoulder down to the cords. I was running Hoosier R6 DOT radial slicks. Hoosier has a great free phone service (if you are using their tires) where you can talk directly with an experienced technical guy about the trouble you are having. So I called them up and described the situation.
    He asked which car I was using, which Hoosiers I was using, which tracks I run on, how long the tires lasted, etc. The problem I ran into was not enough negative camber on the front tires. When you go around a curve, the car leans, and if the tires were straight up and down before the turn, they are now tilting out towards the outside of the corner. What I needed to do was add negative camber, where the tires lean in on the top so that they straighten out to be more perfectly vertical when going thru turns (at racetrack speeds). The reason my left front outside should wore out is because the tracks I ran all go clockwise, so on average there are a lot more right turns than left turns.
    The technician suggested -2 to -2.5 degrees of camber for the front tires, and -1 degree for the rears. He also suggested 1/8 inch of toe-in. These are ideal race settings. Of course, it will wear out your tires more quickly on the inside shoulder during normal driving, so it's somewhat of a tradeoff.
    So I took it to a really good alignment shop (who charged $250 to do it since it was an "exotic", the scumbags...). The alignment from the factory was -1.1 degrees of camber on the front left, -.9 on the front right, and 1/3 inch of toe in on the front. That's a lot of toe-in. 1/3 inch of toe-in translates to .57 degrees.
    The alignment shop dialed up as much front camber as the stock suspension allows, which is -1.5 degrees. We ended up with -1.5 on the front left, -1.2 on the front right, and a reduction in toe-in by .20 degrees front and back.
    Here's what it looked like afterward:
    What I really need is a camber kit to allow adjustment of the front negative camber beyond the -1.5 degree limit. I'm going to keep my eye out for that. Anyone know of where to get one?
    I'll let you know if this setting helps at the track (other than decreasing the tire wear which I think it will, somewhat).
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Junior Member Teutonic_Tamer's Avatar
    Oct 2007
    Swampyland, UK
    Re: Wheel Alignment for Track Use
    Interesting post, thanks.
    So what were the actual manufacturers standard settings then (rather than what it was set at before your adjustments)? Because you have only increased the front camber by 0.3-0.4 degrees!
    And have you run it on the track again? If so, does it change the handling?
    Sean – Independent Motor Vehicle Technician (ret’d)
    ‘07 quattro GmbH Audi B7 RS4 quattro saloon 4.2 FSI V8 32v (BNS) (with CSiC ceramic brakes )
    ‘06/7 VW Golf Mk5 GTI 5dr 2.0T FSI (BWA) DSG, fully loaded, colour coded,
    ‘98/9 Honda CBR600FX - the blueberry trifle
    ‘03 Audi B6 S4 quattro saloon 4.2 V8 40v (BBK) 6sp man, fully loaded (gone, but not forgotten)
    Apr 2008
    USA
    Anyone know offhand what the official alignment specs are?
    Yes, I would have liked to have added a lot more negative camber to the front, but the stock adjustment mechanism there maxes out at -1.5. That's why I need a camber kit.
    Haven't tried it on the track yet. Nov. 1 I will be going back to the same track I ran it on a few weeks ago before the adjustment (Barber Motorsports park in Birminham AL), so it will be a good comparison. I'll let you know if it seems any different.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Here is a summary:
    • Factory camber for the front axle is -1 +/- 1/6 degree, max difference left to right is 1/3 deg.
    • Toe is 1/6 deg per wheel (1/3 deg total).
    • Any time wheels are aligned, BOTH the front and rear must be checked.
    • Wheels should not be aligned until after 1,000 - 2,000 km as it takes that long for the springs to settle.
    • Caution: If the front axle settings are changed, the steering angle sensor must be recalibrated. (for ESP and ABS)
    There is quite a bit more detail in the manual.
    Welcome to R8Talk.com. Please be sure to read the Audi R8 Introduction and Road Map to R8Talk.com! READ THE FRICKIN' INTRODUCTION - THAT'S AN ORDER!
    All I know is that I know nothing - Socrates
    Apr 2008
    USA
    Interesting - thanks Desperado, I think I'll talk to my dealer about that.
    2007 VW GTI MK5
    1992 Acura NSX
    Quote Originally Posted by MotherTucker View Post
    Sorry to bump up an old thread however I'm curious what, if anything, your dealer might have said regarding the need for steering sensor recalibration after alignment.
    Apr 2008
    USA
    Ah, well I didn't ever ask the dealer about it, but I did take my R8 to the dealer for alignment, and all they did was align it.
    I did look into it from other sources, and found that the steering angle sensor is used to detect when the front wheels are not turned, I.e. when they are pointed straight ahead, primarily for ABS purposes. The sensor needs to be recalibrated if you disconnect the steering mechanism or replace the steering wheel or other situations like that. Small symetric changes to alignment typically don't require it.
    Here's some info I found on it, although this is not for an R8.:
    "Calibration permanently stores the current steering whe
    el position as the straight-ahead position in the steering angle sensor EEPROM. Therefore, the front wheels and the steering wheel must be set exactly to the straight-ahead position before calibration. In addition, the vehicle identification number is also read from the instrument cluster and stored permanently in the steering angle sensor EEPROM. On successful completion of calibration, the steering angle sensor fault memory is automatically cleared."
    2007 VW GTI MK5
    1992 Acura NSX
    Aug 2009
    Chicago, IL
    I did the same thing last summer and maxed out the negative camber, etc. I was getting the exact same wear issues on my fronts. The race alignment definitely helps with performance and tire wear. However, we hit the same issue that MotherTruck identified: we couldn't get as much negative camber as we'd like.
    If anyone knows of a good camber kit, there is interest here too.
    2012 TT RS
    2011 Q7 TDI
    2010 Porsche GT3RS
    Apr 2008
    USA
    I heard PPI has one. I called Rich at OEMPlus, and he said he would check into it, but he never called back so I assume he didn't have any luck locating it.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Here's the details on the PPI camber kit: Camber Adjustment: One for track regulars
  1. Suspension Alignment for Track
    By thebishman in forum Wheel and Tire Discussion
    Last Post: 09-08-2011, 11:06 AM
  2. Alignment Specs
    Last Post: 10-07-2010, 01:50 PM
  3. Alignment Settings For Road And Track
    Last Post: 07-30-2010, 04:10 AM
  4. Steering Fluid Cap Alignment
    By MotherTucker in forum Appearance / Body Modifications
    Last Post: 12-22-2009, 01:58 PM
  5. OEM & Track Wheel Alternatives ~ 18" & 19"
    By MichaelP in forum Wheel and Tire Discussion
    Last Post: 08-03-2008, 03:06 PM
