Ceramic Brakes - Page 2
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Ceramic Brakes
  1. #11
    Thumbs up Re: Ceramic Brakes
    Nope ,sorry.I still have to get the hang of this site .Will keep my eyes peeled.If money were no object I'd copy the Audi race cars buying their parts. Basically a Mad Max style renegade loco machine! A race car with a license plate.Keep it safe!
    Apr 2009
    San Diego, CA
    Re: Ceramic Brakes
    I remember seeing this post:
    8th post in this thread R8 on Dymag wheels
    "Old 07-24-2008, 06:49 AM
    MichaelP MichaelP is offline
    Default Re: R8 on Dymag wheels
    Just a performance wheel update claim. From a Dymag distributor site: ".... Carbon Magnesium Car Wheel - Summary The performance gain achieved by reducing the wheel mass (Un-sprung Mass) can be quantified using a factor of six. This means that to achieve the same performance gain by reducing the body mass, it is necessary to remove six times the wheel weight saving.
    Example: A saving of 2Kg Per Wheel x 4 Wheels = Removing 48 Kg from the Bodywork.
    In some instances, Dymag's Carbon Mag wheels have reduced the wheel weight by up to 5Kg per wheel, which equates to saving 120Kg from the bodywork to get the same performance advantage. ...." see, http://www.rotaryart.uk.com/acatalog...Wheels_18.html
    Hum, a potential 264 lbs, that's not insignificant. Still awfully costly however.
    Cheers"
  4. #13
    Apr 2009
    Ft. Lauderdale, Florida
    Re: Ceramic Brakes
    Quote Originally Posted by 10V10 View Post
    Cheers"
    10V10, Thanks for the Quote.
    If I save 11lbs per Rotor + 4lbs per Wheel = 15lbs I am saving a potential 264 lbs.
    Oddly enough it equals the same 264lbs as the Dymag figure you quoted?
    Not Insignificant! $$$
    Styler50
  5. #14
    Apr 2009
    Re: Ceramic Brakes
    Hey Harrison,
    Thanks for the thought.
    I think it will be a bit more of a "Sleeper" if you get my drift.
    There will be a lot of noticeable outward appearance changes for sure but there will also be a few hidden changes as well under the "Skins"
    I should be able to reduce the weight of my exhaust system that I want by about 45lbs or more as I am not certain of the material I will ultimately use Titanium or Stainless. I know I will save more with Titanium but I am working on that as we speak.
    I should also save a bit more weight on some of the outer bodywork, maybe another 50lbs or so.
    In the drivers compartment I am looking at a few options and will keep you posted.
    I think that with all the potential weight savings together with the additional HP increase, I should have a lighter "Including My Wallet", more agile, quicker and I dare say a more responsive car.
    I am enjoying this Forum very much and I appreciate all the input.
    Styler50
  6. #15
    Apr 2009
    Re: Ceramic Brakes
    Quote Originally Posted by bz888 View Post
    Wanna put the R8 on a diet? Rip out the original seats and go for a Carbon Fibre bucket seat. You'll save 30kg instantly!!
    bz888,
    Thanks for the heads-up on the seats.
    Every thought and weight saving ideas will ultimately help.
    Styler50
  7. #16
    Apr 2009
    Re: Ceramic Brakes
    ***More info found***
    Carbon-Ceramic Brake Discs
    Advantages
    At the IAA in Frankfurt in 1999, the carbon-ceramic brake disk had its world premiere. The use of the high-tech material had revolutionized the brake technology: In comparison to the conventional grey cast iron brake disk the carbon-ceramic brake disk weighed round 50 per cent less reducing the un-sprung mass by almost 20 kilograms. Further significant advantages are: improved brake response and fading data, high thermal stableness, no hot judder, excellent pedal feel, improved steering behavior, high abrasion resistance and thus longer life time and the advantage of avoiding almost completely brake dust. At first Porsche AG built the carbon-ceramic brake disk in 2001 into the 911 GT2 as series equipment. Since that time also other premium brands use the advantages of this innovative brake technology for more security and comfort. These are for example sports cars and luxury class limousines from Audi, Bentley, Bugatti and Lamborghini.
    Dimensioning and Design
    The overall car braking system is designed to match a car’s layout and take advantage of the ceramic brake disk material’s properties. SGL Brakes covers the designing of the brake – the construction of the brake disk as well as the selection of the friction layers and the caliper – and adjust the brake into the concept of the vehicle. The main parameters determining the braking system design are a car’s maximum speed, the time sequence of full brake applications possible to bring a car to a stop from top speed and the mass to be braked, in addition to the axle load distribution and the car’s aerodynamics. The purpose of brake disk dimensioning and design is to ensure that a car can be stopped safely under any conceivable driving conditions. Braking system design also needs to ensure that neither the disk itself nor any other component in its direct vicinity is exposed to excessive thermal loads. The optimal cooling vane geometry is determined by numerical methods (Computational Fluid Dynamics) for each car model. The design calculation also takes account of the air pressure building up underneath the car and inside the wheel arch as a function of the car’s aerodynamic design and traveling speed.
    Material
    A special feature of carbon-ceramic brake disks is the ceramic composite material they are made from. Both the carbon-ceramic brake disk body and the friction layers applied to each side consist of carbon fiber-reinforced silicon carbide. The main matrix components are silicon carbide (SiC) and elemental silicon (Si). The reinforcement of the material is provided by carbon fibers (C). Silicon carbide, the main matrix component governs great hardness for the composite material. The carbon fibers make for high mechanical strength and provide the fracture toughness needed in technical applications. The resulting quasiductile properties of the ceramic composite material ensure its resistance to high thermal and mechanical load. Carbon fiber-reinforced silicon carbide materials thus combine the useful properties of carbon fiber-reinforced carbon (C/C) and polycrystalline silicon carbide ceramics. The elongation at break of C/SiC materials ranges from 0.1 to 0.3 %. This is exceptionally high for ceramics. The entire characteristic profile makes fiber-reinforced silicon carbide to a fist-choice material for high-performance brake systems: Particularly the low weight, the hardness, the stable characteristics also in case of high pressure and temperature, the resistance to thermal shock and the quasiductility provide long live time of the brake disk and avoid all problems resulting of loading, which are typical for the classic grey cast iron brake disks.
    Property Unit Material
    C/SiC material, general C/SiC for carbon-
    ceramic brake disk Gray cast iron (GG-20)
    Density g cm-3 1,8 ... 2,9 2,45 7,25
    Tensile strength MPa (=N mm-2) 10 ... 240 20 ... 40 200 ... 250
    Modulus of elasticity GPa 20 ... 240 30 90 ... 110
    Flexural strength MPa (=N mm-2) 20 ... 210 50 ... 80 150 ... 250
    Elongation at break % 0.05 ... 0.8 0.3 0.3 ... 0.8
    Thermal shock resistance
    (second thermal coefficient K') W m-1 26.500 ... 46.000 > 27.000 < 5.400
    Thermal stability °C 1350 1350 approx. 700
    Maximum operating temperature
    (brake disk) °C 1400
    non-oxidizing 900 700
    Linear coefficient of thermal expansion K-1 1.0 ... 3.5 2.6 ... 3.0 9 ... 12
    Thermal conductivity W m-1K-1 20 ... 150 40 54
    Specific heat capacity (cp) kJkg-1K-1 0.6 ... 1.7 0.8 0.5
    Production
    The secret of the advantages of the carbon-ceramic brake disk is the unique production process over approximately 20 days. To produce carbon-ceramic brake disks, SGL BRAKES uses carbon fibers which are given a special protective coating and then cut into short fiber sections of defined thickness and length. The production process includes preparation of the fiber mixture, the production process for the disk body and the bell mounting as well as the final machining of the assembled brake disk. The entire production process is monitored with various tests and ends with one final testing. The production process of the ceramic brake body continues with a preform pressed with binding resin to a so called green body which will be converted in the ceramic component by carbonizing at 900 °C and siliconizing at 1700 °C in high vacuum. The complex feature of the manufacturing process is the use of the “lost core” technology – a plastics matrix which defines the design of the cooling vane geometry and which burns out without residues at carbonizing – as well as the different fiber components of the brake disk body, the friction layers on the ring exterior side and the point-shaped abrasion indicators which are integrated into the friction layer.
    Product Development
    A carbon-ceramic brake is developed in three main stages to match a car’s particular layout: numerical modeling, the construction and testing of prototypes, and testing on an actual car. The brake disk is first simulated numerically on the computer, using the car’s particular model data. The carbon-ceramic brake disk’s diameter, its thickness and the height of the friction path are only some of the parameters calculated on the computer. Calculations for assembled carbon-ceramic brake disks include the design of the bell connection. This is a highly demanding design task because of differences in coefficients of thermal expansion need to be compensated for at any operating temperature possible. The numerical model also provides the design of the cooling vanes configured to optimize fluid dynamics. In the second development stage, prototypes (test specimens) of the carbon-ceramic brake disks are constructed on the basis of numerical model results and bench-tested, together with the matching brake pads and calipers. In the third and final stage, the disk prototypes are tested on the car. They complete not only high-speed runs on a test circuit but also mountain pass descents and road tests. On these test runs, the driver evaluate brake behavior, in particular braking performance and braking comfort, and the computer provides a detailed analysis of measured results. Together with the bench test results, the car test runs determine whether a disk prototype can be approved or not.
    Quality Assurance and Testing
    The braking system is the most important safety system in any car. Carbon-ceramic brake disks therefore need to be manufactured to consistently high quality standards. This is why SGL Brakes has introduced a comprehensive Quality Management System conforming to VDA 6.1 and ISO 9001:2000. The system describes all production and operating processes and also ensures the consistent monitoring and documentation of product quality – from the raw material used to the finished product. The Manufacturing Execution System and a Computer-Aided Quality System are used to implement it. SGL Brakes records all production data and test results for each individual carbon-ceramic brake disk. This allows each disk to be identified both during production and also later when the disk has been mounted on the car. All operations concerned are documented in an Enterprise Resource Planning System and a CAQ System, together with all tests and inspections, the staff and equipment involved, and the results of the tests. Each carbon-ceramic brake disk thus generates around 600 data items during its complete production run.
    http://www.sglgroup.com
    For further information please contact:
    Stefanie Geiger
    E-Mail: stefanie.geiger@sglcarbon.de
    Tel: +49 8271 83-1390
    Fax: +49 8271 83-2493
    ***Filed under: Plants/Manufacturing, Tech, Audi
    Carbon-ceramic brakes
    The sight of a race car streaking into the darkness, brakes aglow as it slows for the next corner, is one of those incredible images that just sticks with you. Those massive carbon-ceramic rotors can take a lot of abuse and their light weight and durability have made them a racing staple for more than 15 years now. Street cars, on the other hand, have been slow to adopt the technology. Although their superior performance is unquestionable, the high cost of carbon-ceramic brakes has made them pretty much exclusive to exotics and supercars.
    Porsche was the first to use them on a street car when they fitted them to the "widowmaker" GT2. Soon after, they found their way onto the "regular" 911 Turbo as well. Now you can get carbon-ceramics on any Ferrari, most Lambos and Porsches, the Bentley Conti GT Diamond and the Audi RS4. But whereas half of Ferrari buyers splurge for the upgrade, only 6% of RS4 owners have done likewise. Why is that? Well, price surely must factor into it.
    Although the carbon-ceramic brake discs last four times longer than conventional steel discs, they cost a heck of a lot more than traditional steel discs: $15 to $20 a disc for steel compared to $665 to $2,660 a disc for carbon-ceramic. That's quite a jump. But there may be hope. By switching from batch production to a continuous process, German manufacturer SGL Carbon AG, along with Audi, are trying to change that. If they can get the process perfected, they are expecting the price per disc to drop all the way down to $465.
    Some still think that's too expensive to generate real mass appeal. Perhaps they'll still primarily be seen on sports cars and exotics, but the new, lower price would make them that much more attainable to the average Joe or Josephine who wants to autocross, say, their Mazda5 on weekends. Click through for the details about the new process and the specifics about why carbon-ceramics are so superior to steel.
    Styler50
  8. #17
    May 2008
    Re: Ceramic Brakes
    Ceramics: Less brake dust, much more hassle finding suitable track brake pads, incredible cost, is the weight reduction reeeeaaallly noticeable?
  9. #18
    Apr 2009
    Re: Ceramic Brakes
    Quote Originally Posted by Craig@Rennstore.com View Post
    Hey Craig,
    By utilizing ceramic brakes and opting for a lighter wheel you will reduce your unsprung weight, effectively shedding pounds off the vehicle not to mention the performance gains.
    I agree that it costs more and your options of pads are limited but, if you are trying to get "everything out of your car" and max out it's potential, YOU WILL NOTICE!
    Styler50
  10. #19
    May 2008
    Re: Ceramic Brakes
    Theoretically yes, but practically - not really.
  11. Remove Advertisements
  1. Ceramic Brakes
    By technomania in forum Wheel and Tire Discussion
    Last Post: 04-21-2012, 10:48 AM
  2. Anyone in the States have ceramic brakes?
    By KfabR8 in forum General Discussion
    Last Post: 09-24-2011, 01:29 PM
  3. Ceramic brakes?
    By HovyR8 in forum Wheel and Tire Discussion
    Last Post: 09-17-2010, 07:12 AM
  4. Ceramic brakes are the best...
    By harrison in forum Wheel and Tire Discussion
    Last Post: 08-27-2010, 06:55 AM
  5. Ceramic vs steel brakes
    By DeeRun in forum Wheel and Tire Discussion
    Last Post: 05-30-2008, 05:07 PM
