R8 Wheel Spacers - Recommendations?
Results 1 to 10 of 13
Thread: R8 Wheel Spacers - Recommendations?
    Mar 2009
    London
    Hi Guys,
    I'm after some wheel spacers for the R8, just wondering what recommendation on size if anyone know?
    15mm Rear 12mm Front?
    Thanks!
    Dan
    Re: R8 Wheel Spacers - Recommendations?
    HRE the Suspension people have 'em in all sizes.Make sure you get the concentric type.I put 10 mm all the way around.You should get the tire sizes you will run first.I played it safe by going same size all around.You can alter the Factories fine handling if you're not carefull. Once I put wide spacers on my 911.then for some reason I tried the car with spacers on the back only and the car became unmanageable. My 2 cents. \"/
    Mar 2009
    London
    thanks Harrison! What you think of 12 All round? how you finding the 10mm all round?
    Oct 2007
    Laguna Niguel, CA, USA
    I think the 10mm looks great on harrison's car, but a 12mm set should be fine too. Don't forget the longer bolts.
    Not to correct, but I think he was referring to H&R (the suspension folks) and not HRE (the wheel folks).
    Yes Rich, I did mean H&R . I really like my 10 mm size. Fortunately I WILL BE ABLE TO CONTINUE WITH 'EM.
    Junior Member Falcon's Avatar
    Nov 2009
    Orlando, FL
    Are the spacers only for custom rims?
    '09 AUDI R8-V8/R-TRONIC/PHANTOM BLACK/BLACK BLADE/TUSCAN BROWN LEATHER
    Not for only custom rims only.
    Mar 2009
    London
    Harrison you got any "down the side" pictures of your car? so I can see the offset of the wheels against the edge of the car body. Would you say 10 is perfect, I was thinking 12mm all around,
    Look forward to seeing some of your pictures!
    Senior Member SDR8's Avatar
    San Diego, CA
    Quote Originally Posted by danko View Post
    he has different wheels on his car now (the offsets are a tad different I think, but very close). You may be able to find some picts in his gallery . He used the spacers with his black chromed wheels too. 2mm is pretty much nothing, so I would not expect much of a difference.
    Oct 2007
    Spacers are great for OEM wheels as well as the custom ones. We often add 8mm-12mm spacers to cars in order to push the wheels out a bit. This improves the track for more stability and give a more aggressive look to boot...
  1. R8 with spacers
    By martin1234 in forum General Discussion
    Last Post: 06-22-2011, 06:27 PM
  2. Wheel Spacers for HRE wheels
    By CALBenzo in forum Wheel and Tire Discussion
    Last Post: 05-02-2011, 08:26 PM
  3. 15mm Spacers
    By CALBenzo in forum Appearance / Body Modifications
    Last Post: 02-06-2011, 03:14 PM
  4. Wheel Spacers
    By WBaker in forum Want To Buy - Parts
    Last Post: 04-30-2010, 11:54 PM
  5. Camcorder Mount Recommendations?
    By desperado in forum General Discussion
    Last Post: 10-06-2008, 07:41 AM
