Suspension Alignment for Track
Results 1 to 10 of 16
Thread: Suspension Alignment for Track
    May 2011
    Topeka, KS
    Quote Originally Posted by gazza1 View Post
    I was in a workshop today getting a wheel alignment for some track work next week and the car was up on the hoist.
    I was quite surprised to see some of the aerodynamic differences between the V10 compared to my old V8.
    There was quite a bit of fine detail work directing airflow under the V10 body that you don't see on the V8.
    So without asking a silly question is the front splitter more suited for the V8 than a V10
    Aesthetically its fair to say its compelling.
    Gazza,
    Can you share the post-alignment settings you chose for the track?
    Bish
    Senior Member gazza1's Avatar
    Australia
    Re: New APR Performance R8 Aero Kit
    Quote Originally Posted by thebishman View Post
    Gazza,
    Bish
    Hi Bish..
    This is what I settled on with the adjustments available.
    Front
    Camber LEFT - 1.8 / Right -1.6 (both maxed)
    Toe - 0
    Caster - left/right + 7.2
    Rear
    Camber - Left - 1.2 / Right - 1.1
    Toe in - -0.5
    Car felt much better on my little twisty mountain road on the way home.
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    May 2011
    Topeka, KS
    Hi Bish..
    Front
    Toe - 0
    Rear
    Toe in - -0.5
    Brilliant. Thanks for the info. Now am awaiting your post-track thoughts.
    Bish
    Front
    Toe - 0
    Rear
    Toe in - -0.5
    Your numbers are very similar to what, after some experiment, I ended up with on my V8:
    Front
    Camber approx -1.4 (both maxed)
    Toe +0.3 (stock)
    Caster ?? (stock)
    Rear
    Camber -1.15
    Toe- +0.3 (stock)
    I still need more negative camber in front, very nice that you can get -1.6 or more. I'd like to add shims so as to get maybe -1.8 or -2.0.
    I tried more negative camber (-1.5) in the rear, but got wheel spin out of the corners and corded the insides. Guessed at the -1.15 and rear tire wear seems very even now.
    Australia
    Car felt better the faster I went..
    I was unsure about zero toe at the front but I had strong straight line stability.
    Running the same Cup tyres as my previous R8..I had less roll under(ploughing) at the front as has been the case previously.
    All in all a good set up
    NISSAN GTR R35
    Dec 2008
    Twin Cities, Minnesota
    In a friend's P997 he over did the negative camber. His front driveshaft diff. broke. It would be nice if we had the numbers from a track setup factory team R8.
    May 2011
    Topeka, KS
    With your MPSC tyres are you running the 305s in the rear and 245 in the front?
    Track cold/hot psi?
    What brake pads?
    TIA, Bish
    Australia
    With your MPSC tyres are you running the 305s in the rear and 245 in the front? -Yes on both
    Track cold/hot psi? - 36psi hot - all round
    What brake pads?- stock held up well,but will upgrade pads for next time.
    NISSAN GTR R35
    May 2011
    Topeka, KS
    Bish
    Miami FL
    Hi Bish..
    Front
    Toe - 0
    Rear
    Toe in - -0.5
    I am trying to copy your parameters for the aligment, the guy at the dealer is asking me if these numbers are in mm or degrees? help appreciated
    thanks
    WIBRAGAL
    2011 AUDI R8 V10 PHANTOM BLACK PEARL / Stasis
    2009 AUDI R8 V8 MATTE BLACK / CARBON FIBER / STASIS....(gone)
  1. Can Coupe Suspension install to Convertible Suspension
    By NA1-T in forum Wheel and Tire Discussion
    Last Post: 08-04-2011, 10:41 AM
  2. Alignment Specs
    Last Post: 10-07-2010, 12:50 PM
  3. Alignment Settings For Road And Track
    Last Post: 07-30-2010, 03:10 AM
  4. Wheel Alignment for Track Use
    By MotherTucker in forum Wheel and Tire Discussion
    Last Post: 02-27-2010, 10:33 AM
  5. Steering Fluid Cap Alignment
    By MotherTucker in forum Appearance / Body Modifications
    Last Post: 12-22-2009, 12:58 PM
