Ground Clearance
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Ground Clearance
    Oct 2006
    Ground Clearance
    Any R8 owners had any problems with ground clearance i.e. speed bumps or parking garage ramps as yet?
    I wonder whether there is enough clearance at the front as it seem to be one of the lowest ( and longest) front overhang I have seen on a car as yet.
    Aug 2007
    Re: Ground Clearance
    Yes
    First day driving home I bottomed it on the uneven road near home, I went straight to my dealer put it up on the ramp to see what had hit, it has some plastic skid blocks either side at the front which it had scuffed,so no damage. Also I overheard the staff at Crawley mention one of the other cars sold was brought back in for a check as the owner caught the underneath attempting to drive up a steep driveway.
    Nov 2006
    Guildford, Surrey,UK
    Quote Originally Posted by R8driver View Post
    Yes
    I was just posting about this in the test drive thread. I personally think its too low for our roads, especially with the long overhang and long wheelbase, especially for an 'everyday' sportscar.
    It would be fine if it had the hydraulic lift option that i had on my lambo, negates any worries and looks awesome in the process!!
    Yph
    Yph is offline
    Jul 2007
    Singapore
    Yes
    This appears very worrisome...
    Ive not seen the r8 in the flesh.... How does the clearance compare to AMV8, GT3 or Elise. These seem to enter the ramps in my office building fine...
    Any owners out there with exact dimensions? much appreciated
    Oct 2006
    Quote Originally Posted by elliot View Post
    How does the hydraulic lift option work, could it be retrofitted?
    Nov 2006
    Basically there is a button on the dash board that lifts the front end of the car by about an extra 6 inches. This could be activated at up to 50mph and dropped down automatically if you went over that speed, it was great for when you new where speed bumps etc were as you could activate it on route and then just zoom over them no probs
    It was an approx £1500 Lambo option but could not be retrofitted, i think its very short sighted of Audi not to offer this when the problem is even worse on the R8 than the Gallardo due to the longer wheel base and front overhang.
    There is going to be a hell of a lot of wincing going on in car parks around the country!
    Senior Member imclueless's Avatar
    Jan 2007
    Newport, Wales
    The first thing I did was check it on my drive. Close but ok.
    I agree it should have a jacking system ala Lambo
    May 2007
    The official ground clearance stated by Audi is 110mm from ground to the R8's lowest point.
    The front of the R8's lowest point is the front bumper at 140mm,
    The rear of the R8's lowest point is 110mm
    The floor pan of the R8 sits at 130mm
    There are strategically placed "scrape points" on the front and on the rear that sit...
    Front = 120mm
    Rear = 110mm
    Senior Member Guilty's Avatar
    Nov 2006
    The Netherlands
    My R8 bottoms also, but mainly on bad roads with some short bumps in it. I do not have any problems with larger speedbumps. Very rarely the smaller ones.
    The odd thing is that it bottoms when I do not expect it and mainly driving between 20 and 35 miles per hour (30 - 50 km/h).
    I checked for damage, but couldn't find any.
    '04 Brilliant Black S4 V8 (Milltek full exhaust)
    '07 Daytona Grey manual R8 - Picked up 30 July 2007
    Oct 2006
    Quote Originally Posted by r8rob View Post
    Front = 120mm
    Rear = 110mm
    Is the plastic undertray below the front overhang designed to be a disposable/easily replaceble part?
    My main concern is coming down ramps in car parks and those steep brick traffic bumps. I assume that the plastic undertray is designed to be a sacrifical part. Is there any danger of the R8 getting stuck?
  1. Where should I jack the car to get it off the ground for winter?
    Last Post: 11-19-2008, 02:20 AM
  2. Ground Clearance
    By chuck123 in forum General Discussion
    Last Post: 02-16-2008, 05:05 PM
