Disable Hill Hold Assist?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Disable Hill Hold Assist?
    Aug 2012
    Great Lakes Region
    I searched the threads but couldn't find anything definitive on this. Can this annoying feature be disabled on a MT car? Hate it!
    2010 4.2 MT, Daytona Gray/Oxygen over Tuscan
    Oct 2011
    Essex, UK
    Re: Disable Hill Hold Assist?
    It can be disabled/activated yes.
    When I flashed my ECU for Ceramic brakes I lost the feature, popped car into Audi and they "ticked the box" again.
    What suprised me was that Audi charge for this feature on a new car but all have the ability to do it.. or not.
    R8 V10 Coupe, R-Tronic in Ibis White - ALL the CF, Heffner Performance TT.
    Senior Member roentgen68's Avatar
    Oct 2011
    Trois-Rivieres, Quebec, Canada
    I searched many many places in the coding with my Vag-Com tools, but never found anything about enabling/disabling this annoying feature...
    There are a few threads on this forum and on others too about this.
    _________________________________________
    Incoming:
    Current:
    2013 Estoril Blue BMW F30 335i xDrive M Sport Package
    2012 White BMW X5 35d Diesel
    2011 Suzuka Grey Audi R8 V10 coupe
    Past:
    2011 Red BMW M3 convertible
    2010 Aprilia RSV4 Factory
    2009 Black 997 911 turbo coupe
    2007 Black 997 Carrera S coupe
    Senior Member Enigma's Avatar
    Dec 2011
    NE Ohio
    Agree... Don't like the Hill Hold Assist either. I let the clutch out and the car's emer. brakes are still engaged (Hill Hold Assist)
    and I don't go.... have stalled the car a couple times now. Here I sit with the clutch engaged and the brake on... must
    wear out the clutch faster this way too...
    I happen to like in Summit County and as the name suggests we have many hills around here.
    I don't need no stinking electronic nanny keeping me from rolling backwards in a MT car.... come on ! (:-)
    Dec 2009
    Tried looking for the coding in vcds this weekend for my TTRS but no dice so far. Must be there somewhere though.
    Senior Member marcuslf's Avatar
    Aug 2011
    Colorado
    I've asked my dealer a couple of times, and they couldn't find a way to turn it off.
    I absolutely hate it. Especially that its nearly impossible to predict when it will let off.
    Sent from AutoGuide.com App
    2012 R8 Ice Silver Spyder. V10, MT.
    1970 Dodge Super Bee. 496 ci big block, 727 Torqueflight
    Oct 2011
    Essex, UK
    I'll get the answer and report back as 100% had mine reinstated !! (RT and steep slopes/hills is where it makes sense)
    Los Angeles
    Quote Originally Posted by Nudenut View Post
    I don't have it but how is it better than briefly using the handbrake on a steep hill to prevent rolling backwards while releasing the clutch in 1st gear?
    Oct 2011
    It is a great idea in the first place. BUT...
    Had it on Porsches and BMWs, but this one implemented in the R8 is not well programmed.
    It holds too much and too late. You have to give it a bit more throttle not to have the engine stall, but when it finally lets go, this "more throttle" gives the car quite a bit of push (too many HPs...). So you have to let go the throttle a bit exactly when the HHA lets go. It's not easy to modulate!!
    Incoming:
    Current:
    Past:
    Aug 2009
    Ottawa, ON, CA
    The trick with the hill assist on the R8 is to only apply enough brake pressure to hold the car on the slope. Don't mash your brake down and then it won't hold the car so hard.
    The hill assist feature does not use the emergency brake it uses the normal brakes and just prevents the back flow of pressure through the ABS system. If you are looking to deactivate it, you need to go in to your brake control module.
  1. V10 2012 wont select gears and hill hold assist malfunction
    By Joegtir in forum Maintenance and Service
    Last Post: 08-12-2012, 06:27 AM
  2. Hill-hold assist
    By EdoctaT in forum General Discussion
    Last Post: 09-22-2011, 02:00 PM
  3. Hill assist malfunction
    By M3R8 in forum General Discussion
    Last Post: 11-22-2010, 06:19 AM
  4. R Tronic Hill Hold assist, can it be added
    By mccltd in forum General Discussion
    Last Post: 11-20-2008, 03:32 PM
  5. any info on hill assist
    By cooperr8 in forum General Discussion
    Last Post: 01-23-2007, 12:50 AM
