2012 Audi R8 V10 Battery Replacement
Results 1 to 10 of 20
Thread: 2012 Audi R8 V10 Battery Replacement
    Jan 2017
    Georgia
    Hey there,
    Wanted to share a quick post about batteries.....first of all Desparado has really helped people out like me. This is really best/safest as a two person job.
    I just want to add a few things......about battery replacement. (all screws are 1/4 turn screws, that work amazing.
    1. You can replace the stock battery with another H6 (43 lbs) or H9 (63 lbs) battery...can be bought at autozone/advance/Interstate etc as they are all likely made in the same factory but I can't verify that.
    2. You do not need a battery minder/charger/keeper while you disconnect the batter for changeout, unless you have push button ignition. Car starts fine and all indicator lights go out after running it for a bit.
    3. I would stick with the H9 as I put the H6 in and it is smaller and I suspect has less cranking power (but no issues in first 24 hrs.)
    4. Removal of the wiper arm is pretty easy even with your hands and no puller, as I did not use a puller. I just folded the wiper arm upright and using both hands rocked it a bit in each direction and voila it came right off.
    5. I suggest removing the FRONT trim piece (where the latch mechanism is) first (using the torx socket); this is somewhat tricky to get back in place at the end, because it has to fit under the front valence and sit in the side trim pieces. Then I would remove the sides pieces (helps if you have a person holding hood upright after hood shocks disconnected).
    6. Then I would Remove the back trim piece (around the window) and it just fits at the lower part of the window. I would remove the mat at bottom of trunk/and jack/tire sealant etc as it makes the trunk lighter as you will remove it STRAIGHT UP.
    7. Lastly I would undo the electrical connection for the cig lighter and then remove the torx screws that hold the manual release for the trunk, but I would not unhook anything until you pull directly up on the trunk a bit, and work the manual release through it's opening (as you want to leave it in the car) I undid the electrical connection for this, though I am not sure I had to.
    Once trunk is out
    Easy to remove the one bolt/bracket that holds the 63 lb battery in place. Then disconnect the terminals and the battery vent (vents gases only).
    Put new battery in and then put everything back in place in reverse order.
    Hope this helps someone.
    Jonathan
    Aug 2016
    South Wales. UK
    A very helpful guide. Thanks for taking the time to write.
    Senior Member S5Cruiser's Avatar
    Jun 2014
    S Cal, USA
    Re: 2012 Audi R8 V10 Battery Replacement
    Thanks for the write up. Given the dealer quote of $650 I may take the time and do this myself.
    Ed
    Hidden Content
    12 R8 V10 Manual Coupe - Daytona GP, Blk Napa, CF Blades, Carbon in Lays, White Faced Gauges, Perf Wheel, Titanium Wheel Pkg
    16 TTS
    15 Mini Cooper S
    Jan 2017
    Georgia
    I just replaced the H6 battery with an H9 and the car seems to have better cranking power. I am glad I did, as it also allowed me to get more competent getting stuff out of the way to change the battery. It is definitely a two person job, as this makes it much easier. If anyone is remotely handy, it can be done with pretty much ZERO skill. I highly recommend doing it, as paying 600 at the dealer is insane, but to each is own. The hardest part if getting the front piece of trim back on and under the front lip of the grille.
    Everyone who owns this car should try to do this (if the need arises) as it is easy on a scale of 1-10 it is a 2.
    Jonathan
    Senior Member WinterRunner's Avatar
    Jul 2015
    USA
    That sounds pretty easy! You say it's a 2 person job, because of the heavy battery to lift it out? I think I could just prop the hood open with something. I am experiencing long cranks to get going, and in the cold it often is even longer. I would assume it's the battery at this point and would love to tackle it myself (with help of a friend possibly). Thoughts?
    Current: 09' R8 CF/Daytona 4.2 V8
    ~Avior resonated exhaust & black tips~LEDs~10mm MTM spacers~OEM euro mirrors~
    ~CQuartz Finest~Tints~Black rings~3 pedals~No questions asked~
    Past: 08' Daytona/Ti RS4 (dearly missed)
  8. #6
    Apr 2011
    DFW, TX
    Very useful writeup! Mine still seems to be working fine, but the battery will be five years old late this year!
    2012 Audi R8 V10| 6MT| Suzuka Grey| Red stitching| CF sideblades, mirrors, interior| Enhanced leather| Illuminated sills| Sport steering wheel| White Instrument Cluster| Dallas Performance Stage 1.5 Twin Turbo| 817whp pump| 950whp 109 octane| GMG springs| Klassen M52R| Toyo R888R| GT Tails| GT wing| CF rear diffuser| Black Optic Grille| Satin black badges
    2015 BMW X5 35d|Mineral White| Mocha
    2017 BMW M3 ZCP| Mineral Grey
    Previous toys: w205 C63S AMG| e82 1M| Several 997's and M3's
  9. #7
    Oct 2014
    Cary
    Thanks for the summary and confidence to hopefully pull this off in the future!
    '12 V10 6MT Ibis White/Black, CF blades, mirrors, interior, window trim, rear vents, Fabspeed non-valved, illuminated sills, Niche 20s
  10. #8
    Jul 2015
    USA
    Awesome write-up, I did it myself this weekend with some help from a buddy, it definitely helps to have an extra set of hands.
    Ended up with a Duralast gold from Autozone for 175$. She seems to crank over MUCH quicker now, let's hope it lasts.
  11. #9
    May 2016
    Santa Clara, CA
    What is the price of the battery?
  12. #10
    Jul 2015
    USA
    I grabbed an Autozone H9 variant (~70lbs, 950 cold amps) for like ~175$ + $18 core, which I got back after exchanging the old.
  1. Battery Replacement - Vent Question
    By SWR II in forum Maintenance and Service
    Last Post: 05-12-2016, 06:29 AM
  2. 2009 Audi R8 battery replacement
    By josephghulmiyyah in forum Maintenance and Service
    Last Post: 02-26-2016, 11:21 AM
  3. Battery Replacement Under Warranty
    By skilly in forum General Discussion
    Last Post: 12-20-2015, 10:44 AM
  4. R8 V8 Dead Battery Time for a Good Replacement
    By Audai_R8 in forum Maintenance and Service
    Last Post: 07-02-2015, 06:59 AM
  5. 2009 Audi R8 battery replacement
    Last Post: 01-10-2015, 04:55 AM
