Anyone else's woefully inaccurate? Mine is terrible, especially in traffic
There are other threads on this.
The gauge gives accurate rreadings when the vehicle is moving with a constant airflow.
In traffic, heat from the engine is not disipated and will cause high readings.
This is normal.
Thanks... should have done a search I guess!
You can also bake a cake in the trunk.
No more R8...Jing jing sold after a year with only 7000km. A people mover as replacement.
Yep.... no good for the weekly food shop![]()
only sports car in the world to come with a built in oven :P
the gauge is sitting behind the rear fender, at the track it shows about 50 C
greetings from Lugano
MIKE
The sender is fitted right in front of the RIGHT FRONT radiator, And will heat up off the latent heat from the rad if stationary.
