Hesitation at low rpm - is it a fault ?
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Hesitation at low rpm - is it a fault ?
    Dec 2007
    Luxembourg/Switzerland/Germany
    Question Hesitation at low rpm - is it a fault ?
    I have over 8,000 km now and one of the few things I dislike with my R8 is the hesitation of the engine at very low revs. It happens rather frequently, and feels a little like a misfire.
    Is that inherent to the engine or is it a fault that I should have my friendly Audi dealer correct ?
    Thanks for any comments and suggestions.
    Rob A
    '08 R8 White/Ice silver - Light grey leather/alcantara
    | Manual - Magnetic Ride - 90 liter tank - Cruise control - Heated seats - Lumbar support - Leather shifter knob - Auto-dimming heated outside mirrors - Auto-dimming interior mirror - Parking system
    '04 Audi A8 4.0TDI
    '04 Mercedes Benz SL 350
    '07 Saab 97x 4.2i
    '04 Range Rover HSE Td6 Diesel
    Mar 2007
    Michigan, USA
    Re: Hesitation at low rpm - is it a fault ?
    If by hesitation you mean it lacks torque, then it's normal. Otherwise, no. I have not experienced that.
    Dec 2007
    No, I don't mean the lack of torque. Since the R8 is my daily driver I don't mind it having split personality. Sedate at low rpm and very fast at high rpm.
    It's definitely a hesitation.
    Rob A
    '04 Audi A8 4.0TDI
    '07 Saab 97x 4.2i
    Feb 2008
    Los Gatos, CA
    I have not noticed this as you describe it. I have an R-Tronic and I have noticed a "hesitation" if I approach a junction or traffic circle and, having slowed down, I want to take off quickly ...I do get the impression that sometimes it can't decide if it wants to go or to shift down to first gear before taking off.
    Apr 2008
    Fareham, UK
    I have a 'glitch' at the bottom of second gear, which is really annoying...!
    2006 RS4 saloon. Avus Silver
    2005 A4 2.0TDi Saloon. S-Line, Black.
    Nov 2007
    Moray Firth
    I've got a flatspot between 3000-3500 RPM but its only noticeable in 3rd.
    I've had an Audi tech check it out on a test drive with me and apparently its just the engine changing between different stages in the map ?
    Its here Born 1/5/08
    Feb 2008
    Do you mean very low revs, for example very slow rolling in 2nd, nearly stopped and then you press the peddle pretty hard it kind of stutters before going? If so yeah I have noticed that on several high powered cars with manuals
    Apr 2008
    Fareham, UK
    The 2nd gear thing is not uncommon, I seem to remember a thread about it on here somewhere.
    Mine is always there - out of first into second at any rpm, then press the pedal, short pause, then off you go again. It almost feels like a misfire.....
    It never does it in any other gear though, very odd.
    Dec 2007
    "like a misfire" is indeed the best description I can think of.
    Not sure whether it is in 2nd gear only. I will have to pay attention to that when I next drive the car. Actually I'm not even sure that it happens consistently.
    Rob A
    '04 Audi A8 4.0TDI
    '07 Saab 97x 4.2i
    Senior Member mad-dot's Avatar
    Glasgow
    Quote Originally Posted by Rob A View Post
    Mine's had this since I got it. It stopped doing it after the recent software upgrade, but did it a couple of times at the weekend. Mostly seems to happen if I boot it at low revs (between 1 and 2k) and usualy in 2nd .Feels like a complete loss of power for a fraction of a second, rather than 1 or 2 cylinders missing.
  1. PLEASE HELP. Navigation Fault code? Please enter PIN?
    By Toankie in forum Maintenance and Service
    Last Post: 11-08-2011, 03:14 PM
  2. slight hesitation when changing into 2nd gear
    By Gord59 in forum Maintenance and Service
    Last Post: 11-06-2011, 11:35 AM
  3. Engine hesitation at 3k revs in 3rd gear?
    By pike98 in forum General Discussion
    Last Post: 03-02-2011, 10:20 AM
  4. 400KM later... ESP FAULT!!!
    By GamerZer0 in forum General Discussion
    Last Post: 11-25-2010, 11:06 AM
  5. Audi R8 Manufacturing Fault Beware
    By bobbychaudhry in forum General Discussion
    Last Post: 01-09-2010, 05:42 AM
