Front bumper's vulnerability?
Results 1 to 10 of 11
Thread: Front bumper's vulnerability?
    Aug 2008
    I am considering between R8 and 997TT, and because roads here aren't very good (lots of speed bumps, sharp hills, road works etc) I was wondering how easily you can hit the ground with front bumper? 997TT has replaceable plastic front lip, so it is easy to change it when get scrathces on it.
    Senior Member r8jon's Avatar
    Mar 2008
    Buckinghamshire, UK
    Re: Front bumper's vulnerability?
    After 18,000 miles, I have only touched the front bumper on the gorund a couple of times, and that was when exiting a downhill type of drive onto a flat road. I have never touched a spped bump with it, if that helps
    Jon P
    2009 - Audi RS6 C6 Chipped to 649bhp
    2008 - Audi R8
    2006 - Audi RS4 B7
    2004 - BMW 330d Chipped (while waiting for B7)
    2001 - Audi RS4 B5
    + other assorted Audi's over the years - UR, 80, TT, A4, S2, S4, S5
    Aug 2008
    Quote Originally Posted by r8jon View Post
    Sounds good What kind of damage those hits did to front bumper?
    Junior Member 60 R8's Avatar
    May 2008
    I see you screen name is Cobra. I'm an X-cobra owner and my street clearance in the R8 is better. I was just under my R8 (on a lift) and noticed what looked like sacrificial areas designed into the belly pan. I had to replace the belly pan on my RS6 once and repaired it once. A couple of the areas on the R8 have a softer rubber scoops (flex and return after scrape - still works as an air scoop) and the there are a few hard rubber bumpers that look like they are hard protective bumpers near oil lines or wires. I pulled into a drive way from the road at an extreme angle, and when I departed hour later a car had parked in a position cut of the angle for the backing out of the drive way. There was a serious elevation change between the drive way and the road surface. I scraped the right front nose (non painted area), and pulled black whisker like plastic material on the lowest part of the air dam. Once up on the lift we took a racer bland and cut of the whiskers and it is hard to see the spot.
    No damage to bumper or visible marks from standing from to the car..
    Mar 2007
    Michigan, USA
    I don't think I've ever scraped while driving on a flat surface, even with bumps, but I did scrape coming down off a poorly elevated driveway once or twice. Speed bumps, train tracks, and bumpy roads won't be an issue if you take them more carefully.
    Jun 2008
    Brisbane Australia
    Mate,
    Forget it, I've got a 991 C4S and the R8 live in Australia good roads and have massive problems with driveway's.
    The Front spoiler is about the same height as Porker but the rear hump is bad new's. had to buy a 4x4 just to go shopping in ??
    SALT
    Senior Member Ti-Mike's Avatar
    Aug 2007
    + Switzerland
    sorry a little off topic.....I will be in Brisbane in the end of October, maybe we have a drink......
    greetings from Lugano
    MIKE
    Mar 2007
    Michigan, USA
    Quote Originally Posted by salchlor View Post
    Mate,
    You hit the rear? Are you joking?
    Mar 2008
    Buckinghamshire, UK
    No visible marks, it just sometimes touches on the bottom side
    Jon P
    2008 - Audi R8
    2006 - Audi RS4 B7
    2001 - Audi RS4 B5
    Aug 2008
    Up! I really want this car, but don't wanna look mug driving a car with broken front bumper... any problems in multi-level car parks etc?
  1. Vag com - front led??
    By JAMESY1010 in forum General Discussion
    Last Post: 08-13-2011, 08:44 AM
  2. front width?
    By dpe_g35 in forum General Discussion
    Last Post: 06-12-2011, 04:54 AM
  3. Front Rim
    By ACSELR8 in forum Want To Buy - Parts
    Last Post: 06-02-2011, 07:18 AM
  4. 265 on the front??
    By harrison in forum Wheel and Tire Discussion
    Last Post: 05-25-2010, 08:18 PM
  5. Front Fog lamps?
    Last Post: 03-21-2009, 11:57 AM
