Rattling Shifter
Results 1 to 7 of 7
Thread: Rattling Shifter
    Mar 2008
    Rattling Shifter
    Quick question:
    I have 2009 6M R8. Still in break in period but I have noticed that sometimes when in third gear and the rpms fall to 1800-2000 the shift will vibrate causing a noticeable rattling in the gate. I have not noticed it in other gears.
    I know some of you will say that I should not let the rpms fall that low in third, and I agree that you would not want to drive at that speed normally but the engine is running perfectly smooth at that speed.
    Any similar experiences, comments?
    Re: Rattling Shifter
    I have experience something similar but not exactly the same. My symptom is 3rd gear sometimes fail to engage and will pop out out gear once in awhile if I am not careful and make sure it is in all the way. I do notice that it vibrates more in 3rd than other gear but not sure if this is what you are referring to. BTW, I met another R8er who also has similar problem as mine so mine is not a one off thing. I have since complained to the dealer twice and as usually they found "nothing wrong"....
    Senior Member Ti-Mike's Avatar
    Aug 2007
    + Switzerland
    do thet already have made the new modifications in the US, there has been a call back in switzerland
    greetings from Lugano
    MIKE
    Quote Originally Posted by Ti-Mike View Post
    Mike, can you give us more detail on the "call back"? Thanks.
    Aug 2007
    + Switzerland
    i will get the papers from the Garage then i will post what excatly they change, some are very little like drilling holes in the lower engine cover to that rain water gets out and so on.
    I will post this next week
    MIKE
    May 2007
    These are vey minor modifications to the early R8's, nothing serious, or anything to do with rattles or popping out of gear.
    Aug 2007
    + Switzerland
    they had to change a little motor on the hydraulic system as the metal contacts are getting loose and the car will not shift anymore and end up in the emergency mode ( only 1 2 3 and R ).
    I was happy because it happened 24 km from home when i arrived at Audi they told me to change this little part is part of the modifications they have to do.
    MIKE
  9. Remove Advertisements
  1. Replies: 3
    Last Post: 01-14-2011, 01:48 AM
  2. Shifter sqeaking
    Last Post: 01-07-2011, 06:35 PM
  3. Rattling sound from engine bay
    By mdc in forum General Discussion
    Last Post: 02-03-2009, 06:47 PM
  4. Rattling Sound After Starting
    By KansasR8 in forum General Discussion
    Last Post: 07-09-2008, 08:48 AM
  5. R-Tronic Shifter - Am I on drugs?
    Last Post: 03-15-2007, 03:30 PM
