Help Engine+clutches overheat!
Results 1 to 10 of 14
Thread: Help Engine+clutches overheat!
    Member Dubai's Avatar
    Jul 2008
    Dubai
    Hi ..
    I am having a problem in my 2009 R8 R-Tronic
    • When I stop the car and the engine is on for some time like 20 minutes (chatting with a friend next to me) the engine heat goes hiiiiiiiigh!!!! and gives me a signal that the engine is overheated !!!!
    • And when I use the sport button to take off from gear one the car doesn't move !!! and gives me a signal saying clutches overheated !!!
    but when not using the sport button the clutches are perfect !!!
    any one with the same issues ????
    2008 - Audi R8
    2009 - FJ Cruiser
    2008 - Suzuki 750 GSXR Bike
    Jul 2008
    Dubai
    Re: Help Engine+clutches overheat!
    2008 - Audi R8
    2009 - FJ Cruiser
    Member Redokee's Avatar
    Aug 2008
    Hungary
    Quote Originally Posted by Dubai View Post
    i think that's not phisycally damage... thats electronic problem
    Junior Member Teutonic_Tamer's Avatar
    Oct 2007
    Swampyland, UK
    Hi ..
    I suspect that may be down to "user error". I really don't think it is good for any engine to be left idling for 20 minutes! 5 minutes max idling, then turn off the engine.
    Is this after idling for 20 minutes, or at all times? Anyway, that sounds like a problem with a temperature sensor on the gearbox, or other related electrical/sensor problem. Get it checked out by the stealer.
    Sean – Independent Motor Vehicle Technician (ret’d)
    ‘07 quattro GmbH Audi B7 RS4 quattro saloon 4.2 FSI V8 32v (BNS) (with CSiC ceramic brakes )
    ‘06/7 VW Golf Mk5 GTI 5dr 2.0T FSI (BWA) DSG, fully loaded, colour coded,
    ‘98/9 Honda CBR600FX - the blueberry trifle
    ‘03 Audi B6 S4 quattro saloon 4.2 V8 40v (BBK) 6sp man, fully loaded (gone, but not forgotten)
    Oct 2008
    Maybe idling the car for 20 minutes in the summer heat of Dubai is too much for a car designed and built in the cool climate of Germany...?
    Seriously though, Taiwan's tropical heat just wreaks havoc on certain cars such as Jaguars here.... They just keep busting.... and my tech (BMW) tells me it's due to the heat and humidity here that the cars can't operate well.....
    Oct 2007
    Swampyland, UK
    Quote Originally Posted by R8Taiwan View Post
    In all seriousnous, all car engines, irrespective of the locality they operate in, really are not designed to be left idling. Only engines specifically designed to run at "low revs", such as massive ships engines, should be run at such low speeds. Even static engines used in generators and the likes will run way above their natural idle.
    The other issue is that when idling, the engine is under a "no load" situation, and this causes accelerated wear on the side of the piston not designed to take such useage.
    Interesting . . . do you have Mk5 Golf GTIs in Taiwan, and if so, do they have the additional coolant radiator behind the left front fog lamp grille?
    Oct 2008
    Quote Originally Posted by Teutonic_Tamer View Post
    My wife's got a Mk5 Golf but I haven't opened to see if that's the case. My tech friend was telling me that there are cooling issues with cars with large cc's such as the Jag, Aston Martin, and Ferrari. Nothing on German cars though. My BMW E60 works very fine as well...
    Jul 2008
    Dubai
    Quote Originally Posted by Redokee View Post
    i hope so !!
    i took my car to the dealer .
    2008 - Audi R8
    2009 - FJ Cruiser
    Jul 2008
    Dubai
    well i know but my friend was talking alot and i couldnt turn off the engine
    it is happening all the time with me i duno why !!!
    2008 - Audi R8
    2009 - FJ Cruiser
    Jul 2008
    Dubai
    No !! come on !!
    my car is with Gulf Specs !!! so it is designed for our heat !!
    2008 - Audi R8
    2009 - FJ Cruiser
  1. Anyone know where to get a 996 engine?
    By KfabR8 in forum Off Topic Discussions
    Last Post: 06-05-2010, 05:31 AM
  2. Replies: 20
    Last Post: 12-31-2009, 12:37 AM
  3. clutch overheat warning
    By weliker8 in forum General Discussion
    Last Post: 09-09-2009, 01:55 PM
  4. Add engine oil on first day?
    By russman in forum General Discussion
    Last Post: 01-18-2009, 08:01 AM
  5. Pic of the v10 engine
    Last Post: 05-15-2008, 06:53 AM
