Anything important underneath the front end of the car near bumper?
Results 1 to 10 of 10
Thread: Anything important underneath the front end of the car near bumper?
    Mar 2007
    Michigan, USA
    I pulled forward into a parking block that I didn't realize was there and scrapped the right corner of the front bumper and pushed it in a little, as in inward, not crumpled. Its the angled portion at the bottom that connects with the plastic strip that extends along the bottom. I felt underneath, and I can feel some cracked/buckled plastic, what feels to be a loose screw, and some plastic that is present on the hit side, but not the other.
    I'll probably end up just buying a new bumper because it's scuffed and scraped badly. I just hope that I didn't break anything expensive or **** up the suspension. I couldn't have hit at it more than a couple miles per hour, and it was nearly against it when it did, so it was more of a pushing motion than an impact.
    The bottom of the car is nearly flat and covered with plastic paneling, right?
    Anyone have pics of the underside? Much appreciated.
    Mar 2007
    Michigan, USA
    Re: Anything important underneath the front end of the car near bumper?
    Force exerted on red, feel a buckle in the blue area. Tried to push and pull on the bumper, but it didn't budge. Wonder if it pressed it, buckled an area of plastic due to a screw through both, then came right back out.
    Hopefully this underbody is just flat plastic with some screws and is cheap.
    There goes the $2500 I won yesterday.
    Very sorry for your little shunt.
    Hmmm, so do you have the parking assist on your car? Was the front assist turned on? Inquiring minds want to know
    (Sorry, don't know the details on what is in that area.)
    Mar 2007
    Michigan, USA
    I do, but parking sensors aren't automatically activated unless you go into reverse. If you want to use the front sensors, you must turn them on manually, which I didn't do because I was pulling away and forgot it was there.
    Oct 2008
    So in comparison to a Porsche 911, is the front more vulnerable to scrapes?
    Mar 2007
    Michigan, USA
    Quote Originally Posted by R8Taiwan View Post
    Nah, that's not a valid conclusion. This was completely due to my stupidity.
    Senior Member geffers's Avatar
    Jan 2007
    Leeds, UK
    both very similar, R8 is a little more difficult to judge I find and a tiny bit lower but the front sensors work well. I find I regularly scrape the bottom of the front spoiler on kerb tops more so than in the 911 but the damage is superficial and not visible except from under the car.
    Nov 2006
    Did exactly the same - nudged the left front in a parking garage against a kerb and pushed the "bumper" in a little. Scraped lower part of bumper, under the crease and below sensors - still needed a new headlamp washer, bumper, lower mounting braket etc to make as good as new. Moral - kerbs are a problem if more than 4 ins high!
    May 2008
    Motor City
    Quote Originally Posted by wedouglas View Post
    Motor City or MGM?
    Mar 2007
    Michigan, USA
    Quote Originally Posted by krpman View Post
    Motor City or MGM?
    Neither actually. Random drawing from a company I do business with.
  1. V12 TDI style front bumper / GT style rear bumper / a new spoiler option
    By jy7785a in forum Appearance / Body Modifications
    Last Post: 02-16-2012, 12:10 AM
  2. R8 GT front bumper Fins
    By Kiran in forum Appearance / Body Modifications
    Last Post: 08-30-2011, 04:26 PM
  3. DIY V10 front bumper convertion
    By mark25 in forum Appearance / Body Modifications
    Last Post: 08-06-2011, 06:58 AM
  4. APR front bumper LIP
    By Dubai in forum Appearance / Body Modifications
    Last Post: 10-20-2009, 06:37 PM
