Just installed Pagid Yellows... problem
Results 1 to 3 of 3
Thread: Just installed Pagid Yellows... problem
    Mar 2007
    Michigan, USA
    Dealer installed Yellows today and I just got back from bedding them in. They sounded fine before hand and fine afterward... for a moment. I then developed a ringing-like LOUD squeal from the front right. It's a recurring squeal that happens ever time the wheel turns a certain amount. The occurrence of the squeal increases in frequency as speed increases. It doesn't happen when I brake and will disappear for a bit after some hard breaking of letting the car sit for a bit.
    It comes only from the front right and is extremely loud.
    What do you think could be causing this contact?
    Apr 2008
    USA
    Re: Just installed Pagid Yellows... problem
    Sounds like the pad is a bit loose when the pistons are not pressing on it. It will probably go away with time. But meanwhile, I suggest you remove the wheel and check to make sure your rotor or wheel hub nut are not loose. That's unlikely, but can be a dangerous situation. Also remove and inspect the pads in that caliper to make sure all is as it should be. Even though you have bedded the pads, they still need to wear in a lot more before they fully mate with the rotor surface. So if everything looks fine, you probably need to drive it and let it settle in. Those are extremely hard racing pads, they are going to be noisey unless you get them very hot at a race track.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Aug 2008
    They just do it - need a really good 'thrash' to get rid of the squealing.
  1. Pagid RS29 Rear Pads for Audi R8
    By exige in forum For Sale - Parts
    Last Post: 08-02-2011, 04:20 AM
  2. Pagid Damaged my Rotors?
    By bz888 in forum Wheel and Tire Discussion
    Last Post: 06-21-2011, 06:40 PM
  3. V8 R8 Coupe - Problem after problem - My consumer rights?
  4. PAGID Brake Pad Specifications
    By MotherTucker in forum Wheel and Tire Discussion
    Last Post: 02-09-2010, 02:14 PM
  5. Brake Pads - What did you guys pay for your Pagids Yellows/Blues?
    By Craig@Rennstore.com in forum Performance Modifications
    Last Post: 05-30-2008, 05:23 PM
