Reverse Gear Problem
Results 1 to 6 of 6
Thread: Reverse Gear Problem
    Dec 2007
    Seoul, Korea
    I'm having a problem with my reverse gear. It won't go all the way in. The gear itself has no problems, but if you look at the gear gate, it looks as if the reverse gear is only halfway in the gate. Anyone else have this problem?
    Senior Member gazza1's Avatar
    Australia
    Re: Reverse Gear Problem
    Never ever had the problem with reverse gear in 7000k.Always slides to engagement perfectly everytime.
    Just for the record though Audi is air freighting a new gearbox for my R8 from germany.
    The gearbox functions perfectly but has a slight noise which they thought required a new box.
    I would expect that Audi would find the solution you require.
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    Member Redokee's Avatar
    Aug 2008
    Hungary
    try press the clutch 2times before select R
    Just have my gearbox replaced. My problem is 3rd gear. It didn't really go all the way in and could popped out if not careful. The new one is much better. Maybe you should try talk to Audi.
    Senior Member 09R8's Avatar
    Los Altos, CA
    under warranty. I hope this is not similar to the SMG issues to the first gen E60 M5s / M6s
    '11 Rosso 458 Italia
    '05 Black Carrera GT
    '10 DG R8 V10
    *Sold
    '08 ClK63 BS
    '04 Gallardo E-gear
    '03 Rosso Corsa 360 Modena
    '07 RS4
    '06 RR Supercharged
    Senior Member MikeB's Avatar
    Aug 2008
    Highlands, UK
    Part of the 'high value upgrade' that they carried out to my 09 was a mod to the gear selector, but not sure what it involved. It did not make any difference to mine, 3rd gear is a little stiff until it warms up, but you might ask your dealer about it.
    S4 B7 AVANT 4.2L V8
    A1 1.4 TFSI
    WWW.GTCARTOURS.CO.UK
  8. Remove Advertisements
  1. Possible to retrofit Reverse sensors and camera
    By Daark in forum General Discussion
    Last Post: 07-03-2011, 12:08 PM
  2. V8 R8 Coupe - Problem after problem - My consumer rights?
  3. 6 Speed folks - Reverse straight to 1st
    By lightninhopkins in forum General Discussion
    Last Post: 07-02-2009, 11:53 AM
  4. R-tronic problem; engaging 4th gear on a trailing throttle
    By DeeRun in forum General Discussion
    Last Post: 07-02-2009, 10:00 AM
  5. Aftermarket Reverse camera kit
    By mccltd in forum General Discussion
    Last Post: 02-10-2009, 09:24 AM
