Heated Seats retrofit
Results 1 to 4 of 4
Thread: Heated Seats retrofit
    Nov 2008
    Kent, UK
    Just found an R8 i'm interested in.
    Has the spec i'm after but no heated seats. I love my heated seats.
    Do you think they would be easy to fit.
    I dont know how easy the leather comes off the seats.
    I used to be a vehicle technician, took plenty of seats out but never looked to how the covering is fitted on them.
    Does anyone without electric seats know if the wiring is in place behind the switch blanks?
    If so I would then buy a universal kit and try and fit them myself.
    thanks
    Dave.
    M3 E46 SMG Convertible
    M3 E46 Coupe
    Imprezza STi Turbo UK
    Imprezza Turbo
    Sep 2006
    Herts, U.K.
    Re: Heated Seats retrofit
    Hi Dave,
    You seem to be searching for your "exact" spec, B&O, CD changer, heated seats. etc. I wish you luck finding it.
    Some car manufacturers have a universal wiring loom. Others do not. Since these cars are built to customer spec, I doubt they will have redundant leads and connectors. An Audi tech would be the best person to ask.
    I have heated seats and they are nice. I guess the heating pad in buried in the middle of the seat, so not sure how much of it you have to take apart.
    One thing you overlooked is the switches for the seats. These are rotary drum type switches that go on the panel just behind the gear stick.
    So, best case, you are going to have to get behind this panel to fit the switches and pull apart the seats. Worst case, you will need to pull apart the seats, wire to the seats, fit the switches and wire them to the fusebox (behind passenger footwell).........
    Good luck !
    Nov 2008
    Kent, UK
    Thanks R8,
    I am fussy. Every car I have found so far has had one option missing that im after. For example one car had every extra and no bluetooth, another had loads of extras no B&O and this one has all that I want but no heated seats, and would you believe a car that ticked all my boxes sold 20minutes before I rang and they had it for sale for 3 weeks. Typical.
    Maybe I should settle for this one and a hot water bottle.
    M3 E46 Coupe
    Imprezza Turbo
    Dec 2007
    Seoul, Korea
    I personally do not recommend retrofitting the heated seats. I think you should find an R8 with the specs that you want. There are tons out there right now.
  6. Remove Advertisements
  1. Diy retrofit oem full led
    By bubblerage in forum Appearance / Body Modifications
    Last Post: 08-09-2011, 01:47 PM
  2. V10 LED DRL Retrofit
    By FiftyPence in forum OEMplus
    Last Post: 07-17-2011, 03:21 PM
  3. Navigation Retrofit?
    By pw78 in forum General Discussion
    Last Post: 04-01-2011, 04:53 PM
  4. Retrofit HBA
    Last Post: 01-05-2010, 11:20 AM
  5. Retrofit of nav in premium pkg R8 possible?
    By gsmps in forum General Discussion
    Last Post: 01-14-2009, 07:14 AM
