SD Card - HC or Non HC
Results 1 to 8 of 8
Thread: SD Card - HC or Non HC
    Jan 2009
    Dorset, UK
    Just went out and purchased some Sandisk 4GB cards only to realise they are HC.
    Before I take them back to the shop can someone confirm that the card reader WILL NOT read HC cards.
    Is this correct?
    Guest
    Middlesbrough, UK
    Re: SD Card - HC or Non HC
    With the new nav (or the AMI i'm not sure) you can have up to 32GB SDHC cards if i remember right. With the old one or without AMI you can have up to 8GB SD cards?
    Guest
    Middlesbrough, UK
    http://www.fourtitude.com/news/publi...cle_5095.shtml There ya go
    On the back of the display, which can be folded away at the push of a button, are two slots for SD and SDHC cards with capacities of up to 32 GB. With the new 3rd Gen MMI.
    Senior Member SDR8's Avatar
    San Diego, CA
    It does depend on which unit is in your dash. If you have a 2009 or older, you will need the non-HC cards (usually up to 2GB cards, there are some 4GB non-HC but can be hard to find). If you have one of the newer 2010 cars with the new unit, they can handle the SDHC cards.
    Guest
    Middlesbrough, UK
    It does depend on which unit is in your dash. If you have a 2009 or older, you will need the non-HC cards. If you have one of the newer 2010 cars with the new unit, they can handle the SDHC cards.
    You put it a lot simpler than i did
    Jan 2009
    Dorset, UK
    Cheers guys! Mines a 2008 car so I'll stick to 2GB cards!
    May 2008
    PA, USA
    I've actually managed to get a 4GB non-sdhc card from amazon. There's a link in the previous topic discussing this
    Italy
    on new MMI RSN-E (my 2010) with AMI
    limit for slot any is 64GB (SD with HC, SDHC)
  10. Remove Advertisements
  1. using the SD card
    By eliouno in forum General Discussion
    Last Post: 09-17-2011, 07:30 AM
  2. SD Card or Ipod
    By jjg in forum General Discussion
    Last Post: 11-25-2010, 03:53 PM
  3. SD card question
    By ignomini in forum General Discussion
    Last Post: 10-07-2010, 08:22 AM
  4. 4GB SD card help
    Last Post: 08-07-2008, 10:23 PM
  5. SD Card capacity?
    By benflux in forum General Discussion
    Last Post: 04-16-2008, 08:57 AM
