Squeakingnoise from engine compartment
Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: Squeakingnoise from engine compartment
    My V8 R8, with Carbon Fiber trimmed engine compartment has developed the habit of emitting a rubbing/squeaking noise, from behind the seats, after the car has warmed up and has been run. I get the feeling that it has something to do with the CF panels rubbing, but I don't know where to start diagnosing the problem. Has anyone had this problem and what is the solution?
    Re: Squeakingnoise from engine compartment
    Sounds like a dealer problem to me. Audi generally add a small cloth strip on the edge of any panel that touches another (see the edge of the radio surround where it touches the monoposto). I also saw an Audi bulletin for the CF sideblades which added some foam/felt rubbing pads. Get the dealer to sort and give you a V10 or RS6 for playtime.
    Best Regards, Ian
    Dec 2008
    Twin Cities, Minnesota
    I had a rubbing noise where the engine cover touched the carbon fiber on passenger side. You could see a worn area on the CF. The dealer put in a pad and the noise disappeared.
    Guest
    Middlesbrough, UK
    Did they replace the CF that was worn? Or did the pad cover it up so it wasn't noticeable?
    Jan 2009
    Houston, TX, USA
    If you're a very young couple, (teens), the squeaking from the rear of ANY car might be from something else entirely!
    Jul 2008
    Dubai, UAE
    Hmm I've also recently starting hearing a squeak from what seems to be the engine bay / somewhere behind the seats. Going over any small bumps makes it squeak in time with the bumps Could you say approximately where in the engine bay the rubbing was happening?
    Senior Member MikeB's Avatar
    Aug 2008
    Highlands, UK
    I had a squeak which sounded like it was coming from the foam in the bulkhead behind the seats. It was v irritating when going over a bumpy surface, but I knew I was getting shot of the car. I now have a squeak in the new car around the cd player - can't win!
    S4 B7 AVANT 4.2L V8
    A1 1.4 TFSI
    WWW.GTCARTOURS.CO.UK
    Jul 2008
    Dubai, UAE
    That sounds a bit more like mine actually at least its pretty quiet
    What IS quite annoying though is that my windows (driver side especially) have developed a 'squeak' when going up/down, which I think was discussed in another thread, I'm going to get them to look at it soon.
    Quote Originally Posted by MikeB View Post
    I am pretty sure their is an Audi bulletin on this...
    Best Regards, Ian
    I went to the dealer today. Tech said the noise was coming from clips that hold the high m ount brake light in place. Car will be serviced next Monday.........we will see.
  1. Engine compartment lid stuck?
    By hblocal in forum Maintenance and Service
    Last Post: 10-14-2011, 12:02 PM
  2. Engine Compartment
    By mark25 in forum Appearance / Body Modifications
    Last Post: 11-14-2010, 03:09 AM
  3. L.e.d. engine compartment lights
    Last Post: 10-18-2010, 09:35 PM
  4. engine compartment help
    By DSI in forum General Discussion
    Last Post: 06-07-2010, 07:03 AM
  5. Lighting for the Engine Compartment
    By KYK in forum General Discussion
    Last Post: 01-30-2008, 12:26 AM
