Problem with Magnetic Ride Control
Results 1 to 10 of 16
Thread: Problem with Magnetic Ride Control
    Member Levan's Avatar
    Moscow
    Thumbs down Problem with Magnetic Ride Control
    Dear All,
    After the diagnostics performed by dealer I’ve got the information that 3 of 4 magnetic shock absorbers are out of order (leak found).
    According the information I’ve got the shock absorbers have limited warranty (6 month or 10 000km).
    And the most interesting is cost: 10 000 Euro for 4 shock absorbers…
    Are they crazy or I am?!
    Any warranty or goodwill experience in this case?!
    P.S.: R8 appears to be not the most robust vehicle I’ve ever seen. In my case 1 year 25 000km caused:
    1. Four absorbers to be exchanged 10 000Euro
    2. Gearbox malfunction 15 000Euro
    3. Lacquer problems (door seals) ???
    4. Headlamp mist 8 000Euro
    WTF!?!!!
    AUDI R8 4.2 Ibis White Carbon
    PORSCHE 911 turbo Guards RED
    Mitsubishi Evo VIII Stage I Raven
    Moscow outlaw gang.
    Dec 2008
    Twin Cities, Minnesota
    Re: Problem with Magnetic Ride Control
    Where are you located? How many miles are on your vehicle? I thought everything was covered with Audi care up to 40,000 miles. 33,000 euros of maintenance is nuts. All of the items listed in your post should be covered by warranty!
    Guest
    Middlesbrough, UK
    You get charged more for being in the 'moscow outlaw gang'
    Moscow
    Quote Originally Posted by mngolfer1 View Post
    I reside in Moscow. The millage is 15 000 miles.
    I thought AUDI will take care as well...nuts, right.
    Quote Originally Posted by Davey_Dee View Post
    Most likely...
    Moscow outlaw gang.
    Thumbs up Re: Problem with Magnetic Ride Control
    You have the option of using a different shock/spring set-up, which you can probably suggest to the rest of the MOB .You will dig it ! No worries mate/comrad.
    Naples, FL
    My car was delivered by the dealer with a bad shock. The suspension warning light came on two hours after leaving the dealer.
    I also had to have a leaking steering rack replaced at under 17,000 miles.
    Moscow
    Have ordered new set of MRC shock absorbers...
    Moscow outlaw gang.
    How much lower , Front and rear? The little kid in me wants to slam my R8 to the ground.For more Ground and Pound !!
    If you do, there'll be more ground(ing) for sure....
    Best Regards, Ian
    Smile Re: Problem with Magnetic Ride Control
    I have no more grounding since I learned the extreme turning in technique at driveways.I think if I am even MORE careful, I could handle 1/2 inch up front and 3/4 in rear.Not much but enough to get rid of the ugly space between fender and tire. Clearly a BIMMER trick. I have noticed that most BMW cars (around me)have been lowered to the LIMIT. A business card barely fits between fender and tire--yet, no rubbing.
  1. R8 Coupe without magnetic ride
    By Ballistic in forum General Discussion
    Last Post: 11-30-2011, 06:15 AM
  2. Ride quality on non-magnetic ride R8?
    By IS2000 in forum General Discussion
    Last Post: 10-04-2011, 11:02 AM
  3. Need of Magnetic ride Solenoids
    By Reddy in forum Want To Buy - Parts
    Last Post: 08-31-2011, 09:25 PM
  4. Audi Magnetic Ride
    By liverpoolish in forum Wheel and Tire Discussion
    Last Post: 08-04-2009, 03:07 PM
  5. Magnetic ride ... STD or not?
    By Guilty in forum Wheel and Tire Discussion
    Last Post: 03-03-2007, 01:02 PM
