Is my AirCon kaput?
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Is my AirCon kaput?
    Jan 2009
    Dorset, UK
    Is my AirCon kaput?
    In this freezing weather I still get hot in the car so went to turn the aircon down to very low (as far as it would go) on Auto and it was throwing out warm air.
    Is my system up the creek and maybe needing re-charging OR is there an external sensor telling it to stay warm as the external temp is at zero?
    Thanks!
    Re: Is my AirCon kaput?
    the heat exchanger could be iced up? I'll try it on mine on the way home tonight...
    (could you not just open the window ;-) ;-) :-)
    Best Regards, Ian
    Jan 2009
    Dorset, UK
    Quote Originally Posted by ianerrid View Post
    That's what I keep doing
    Tried mine just now, and it blew cold air out...
    Best Regards, Ian
    Feb 2008
    Los Gatos, CA
    Quote Originally Posted by Garyhun View Post
    Thanks!
    Never had a problem with mine (on a regular basis we get the sort of weather you are having!!).
    Usually below about 4 degrees C the aircon compressor will not come on and the air will simply be heated and them mixed with fresh cold air drawn in from outside to give the temperature you have set ... so I don't think it is your aircon which is misbehaving but the temp sensor or mechanism which controls the mixing of warm air and the cold air.
    Jan 2009
    Dorset, UK
    Cheers guys. Looks like a trip to the dealer!
    Jan 2009
    Dorset, UK
    Just thought I'd provide an update - in case anyone was interested. No? Oh never mind then...
    Dealer called today to tell me the Aircon unit is totally knackered. Dealer has ordered a complete new unit for installation on Monday. All under warranty!
    Feb 2008
    Los Gatos, CA
    Yes ... I am interested. Did the dealer say which part was kaput?
    Jan 2009
    Dorset, UK
    No. They just said it was "unrepairable" so a new entire unit would be installed. I guess it's more a case of "not feasible to fix economically" so might as well trash the entire unit - only 20 months old. But who knows. I'm just happy to get a nice, new, fresh out of the box, unit.
    Lots of parts in the frame though, the ECU, compressor, condensor, rads etc. Hope you're back on the road soon!
    Best Regards, Ian
