rough noise while revving?
Results 1 to 10 of 13
Thread: rough noise while revving?
    Jan 2010
    Guys, just got my V8 R-tronic today and while taking her out for a run-in drive, I notice an excessive noise, sounded like "asthma" or rough air noise that seem to come from the base of the car or near the air vent. Could not quite pinpoint exactly where but does not seem to come from the engine.
    This noise comes about while revving or tapping on the gas pedal around the lower end of the gear ratio (just before downshift), especially on 2nd and 3rd gear. It goes away once the rev/acceleration picks up.
    Anyone with such unusual noise? Seems abnormal to me. Could it be because it is still running in and the mechanical parts are yet to settle in?
    Re: rough noise while revving?
    Does sound abnormal to me. \"/ May be somebody has experienced this breifly or at all ? \"/
    May 2008
    PA, USA
    Offtopic, but Harrison, what's \"/?
    2009 Audi R8 (Silver)
    2010 Audi S5 (Silver)
    2011 Audi Q5 (Sexy Brown)
    2012 Tesla Model S (Soon?)
    It's my seal of approval. \"/ = Good times /"\ = bad times.My version of faces ! Just trying to be different. (more)
    Senior Member Whirlinturbin's Avatar
    Aug 2008
    The ATL
    Would you characterize the sound as a "fluttering" or "clacking," similar to a playing card in a bicycle spoke?
    Does it appear to come on between 1,800 and 3,500 rpm, dissipating by 4,000 rpm?
    Does it respond to throttle imput?
    Do you hear it at highway speed with the radio and HVAC turned off?
    Is yes to three or more of these, I had this problem checked out last week.
    Jan 2010
    Quote Originally Posted by Whirlinturbin View Post
    Hi. It's not fluttering noise. Yes, it respond to throttle input at low gear around 1200-1500 rpm. Sounded "sandy", like some sort of frictions somewhere around the air vent/bottom rear area of the car. Goes away after rev meter exceeds 2,000+. It seem to come from mechanical parts of the gear. Dont hear it on idle or cruising speed. Only low rpm rev on 2-4 gear range.
    Quote Originally Posted by fireplace63 View Post
    Capture it and put in on youtube as this one 'sounds' intriguing...
    Best Regards, Ian
    Jan 2009
    Dorset, UK
    It's my seal of approval. "/ = Good times /" = bad times.My version of faces ! Just trying to be different. (more)
    It's only "different" if it's used on special occasions. It's used on practically every post you make!!!!!
    Maybe the sound comes from a passenger, who is grunting from the G-Forces ? \"/
    Jul 2008
    Dubai, UAE
    It says in the service manual that the engine speed should never drop below 1500 RPM and you should always downshift when the engine starts to feel 'rough' or something to that extent. So if you're cruising with the engine around the 1500 RPM or lower area that could be at fault. May have nothing to do with it though
    Also not really on topic but how are the Corsa's Harrison?
    09 V8 R8, Jet Blue/Carbon blades, CF mirrors, R-Tronic, all CF options, black interior with Victoria Blue stitching
  1. Help with exhaust noise
    By a7MeDiNo in forum Exhaust Systems
    Last Post: 11-04-2011, 06:53 AM
  2. Help with vibration noise
    By drgek in forum Maintenance and Service
    Last Post: 10-09-2011, 07:17 PM
  3. Stasis exhaust causing engine revving??
    By Moncho in forum General Discussion
    Last Post: 09-25-2011, 08:05 AM
  4. rough idle on v10
    By bort in forum Maintenance and Service
    Last Post: 08-20-2011, 07:20 AM
  5. Help with exhaust noise
    By a7MeDiNo in forum Performance Modifications
    Last Post: 08-14-2011, 07:00 AM
