Bonnet stuck :(
Results 1 to 9 of 9
Thread: Bonnet stuck :(
    Apr 2010
    Birmingham, UK
    Bonnet stuck :(
    Hey guys
    My 2008 (08 plate) R8 V8 was delivered on Friday and all I can say is wow what an amazing car. Everything seems to be in perfect condition. Something strange happened yesterday tho where the bonnet just wouldnt open. Has anyone experienced this problem? There is meant to be a release cord you can pull by the passengers foot area but apparently you need to tug it really hard. I am thinking it maybe easier just to let Audi try and fix this as its still under warranty.
    Thanks in advance
    Jan 2010
    Re: Bonnet stuck :(
    Please could you update your profile, then we could see where you are based ie USA or UK.
    So you pressed the button on the keyfob or the button next to the drivers side door handle which did the primary bonnet release then you tried to squeeze the lever under the bonnet and it would not raise? I am just trying to clarify whether you realised you have to squeeze the lever under the bonnet to open it or just expected it to open from the initial button press alone.
    Re: Bonnet stuck :(
    Like Fifty said - push the button on the arm rest, or the key fob. Slip your hand under the front edge of the hood (bonnet is not a USA term, so I'm betting Mark's not from the States) right in front of the Audi Rings and there's a secondary release. The bonnet (er, hood) should pop up about 10-15 mm if the releases are working.
    The pull cord is up under the dash and yes, you have to pull very hard to get it to release. I had to pull "scary" hard the one time I had to use it. Hard on fingers...
    It's not uncommon to have one of the releases (there are three - one over each wheel, one in the middle up front) to not let go completely on some of our cars.
    I've had the left side one adjusted, then replaced and it still will not play nicely on occasion. A second bump of either of the electronic release buttons (arm rest, key fob) will make it let go.
    Quick question - does the R Tronic have to be in neutral for the button to work? I'm wondering if that could be part of Mark's issue? Totally a guess on my part, though - I have the fun stick, not the paddles.
    The six speed will release as long as the speed's under about 1 or 2 mph. Stopped or just ever so slightly rolling and it will open. No, I don't try to open it when I'm moving - I've bumped the wrong button when rolling up to the fuel pump a couple of times and was surprised to discover that the hood would pop open w/the car in motion.
    Jan 2010
    Re: Bonnet stuck :(
    R-Tronic may have to be in gear for the bonnet to open because when you turn off the engine the car beeps at you to put it into a gear to prevent it rolling. I've never let it beep whilst in neutral and then tried to open the bonnet.
    Feb 2008
    Los Gatos, CA
    Re: Bonnet stuck :(
    Quote Originally Posted by FiftyPence View Post
    R-Tronic does not have to be in gear for the bonnet/hood to be opened when the car is stationary.
    Senior Member NASA R8's Avatar
    Jan 2009
    Santa Cruz Mountains, CA
    Cool Re: Bonnet stuck :(
    I have had problems with the driver side (left side in the US) but have been able to press the door button or key fob button a second time to get it to release. Have had Audi look at it but because it is intermittent they have done nothing because it never seems to to it when it is in for service. Have never had to resort to the manual pull.
    Apr 2008
    USA
    Re: Bonnet stuck :(
    Mine does that (one of the three latches doesn't release) quite often. The pneumatic struts just don't seem to have enough oomph to pop it up sufficiently. I tried lubricating the hinges really well, but that didn't help. What I do now is lift up on the bonnet when I press the button. It's easiest with the key fob, but you can do it with the button on the door if you stand outside by the open door and lift the bonnet at the wheel well as you push the button.
    It's one of the few flaws I've ever found in the car.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Re: Bonnet stuck :(
    Mine only recently started doing this. So something must have gotten weaker over time.
    Re: Bonnet stuck :(
    I too have the problem, but only very occasionally. Usually, it is operator induced. Particularly, one of the side latches will catch when the hood is lowered but not latched, then if you try to reopen it you can't get it free. Best solution is to then fully latch the hood, then start the process over again. I've never had it fail to fully unlatch on the second try.
  11. Remove Advertisements
  1. Bonnet/hood won't open!
    By mad-dot in forum Maintenance and Service
    Last Post: 03-16-2012, 11:49 AM
  2. Stuck Paddle shifter
    By thezman in forum Maintenance and Service
    Last Post: 10-05-2011, 10:31 AM
  3. Spoiler stuck
    By Radius8 in forum General Discussion
    Last Post: 06-21-2011, 05:48 AM
  4. paddle shifter .. stuck !
    By 050 in forum General Discussion
    Last Post: 09-21-2010, 02:48 PM
  5. Front lid stuck shut!
    Last Post: 05-23-2010, 01:08 PM
