Check engine light..again
Results 1 to 10 of 18
Thread: Check engine light..again
    Jan 2010
    Rehoboth beach DE
    For the third time in 6000 miles, my check engine light is on. The previous two times were cylinder misfires. Ecu flashed 4k miles ago- thought it fixed misfires. Only use tier one shell premium fuel. The latest misfire occurred in stop and go traffic. Car has rough idle when initially started (not sure if that is a related issue).
    Any thoughts?
    Jeff
    2010 V10 R8
    Re: Check engine light..again
    As you're in the US, the rough idle can't be the cold start 'run fast/valve open' to me it sounds like a engine problem. It almost sounds like a plug fouling problem, I'd get it checked out by the dealer - they'll hook it up to the diagnostic computer and see if it has had any errors flagged.
    Assume you rag it properly?
    Best Regards, Ian
    Just for grins, make sure your gas cap is completely seated - turn it one full turn after it clicks. If the cap's not seating fully, it can throw a code.
    Rough idle at start up was described in a much earlier post: The monster wakes up, grumbles, farts, scratches it's balls, takes a deep breath and then settles down.
    Mine will not wake up on the wrong side of the bed all the time, but when it does, a quick stab of the fun pedal after it's been running for 30 seconds or so (to make sure oil pressure's up and flowing) to about 4K and it's all good from there.
    There doesn't seem to be anything that I've been able to correlate between the days that it's grumpy and the day's it's happy when I wake it up.
    Apr 2008
    USA
    Sounds very similar to mine. Rough, loud idle at startup when cold (especially since a particular engine software upgrade was done about a year ago), and very occasional misfires. All my misfires were at the track, i.e. when I was running the engine hard and hot. Audi's are known to have a tendency toward carbon buildup, especially those with sports-tuned engines. Occasionally a bit of carbon breaks loose and gets in the valves momentarily and causes the misfire. I use my Vag-Com to check that the CEL is due to a misfire, and then I clear the error code. I've had my car almost 2 years now, and have had 3 misfires.
    I talked to the dealer about it, and they actually recommended I run the engine hard and hot to clear out the carbon buildup. They say they have more carbon buildup problems with cars that are always driven very mildly. So they like that I track it. Pretty good
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Senior Member R84ME's Avatar
    Aug 2008
    Arizona, USA
    Quote Originally Posted by MotherTucker View Post
    mt
    All true! Most people wimp around in town (I'm guilty too!) and the engine just does not get hot enough to keep itself clean. You saw those cherry red exhaust stacks in the R8 production video, right? Smokin' hot!
    The same goes for brakes and brake squeal. They can glaze up REAL easy driving around town all the time. The pads & rotors need to realize a few good 70->0 panic stops and a lot of activity to stay clean. I try do this but don't do it as often as I should. My right front consistently runs on the verge of squealing but a few good stops will shut it up.
    These cars were designed to run hot and hard, but very few get to.
    Apr 2008
    Scottsdale Arizona
    Love the information on this website, I will have to remember to drive my car HARD when I get it.
    Tonny
    Yes, from the moment you put your rear end in the seat.
    The engine's broken in as it comes from the factory, so don't worry about bouncing it off the rev limiter "too soon". Just make sure that before you get on the fun pedal that the water AND oil temps are in the operating zone. Oil's temp is probably more important than the water when the car's cold. Make sure it's up.
    Oct 2008
    Idaho
    Have you done the exhaust mod? I was throwing faults after the rough idle update and they only stopped when I reversed the mod. I can't figure out how it had anything to do with it but it seemed to work.
    Apr 2010
    Colorado
    Quote Originally Posted by R84ME View Post
    Many RS4 (which has essentially the same engine) owners have complained about the carbon build up issue. Just peak into the Rs4 forum in quattroworld. I am not sure I agree that driving the car hard fixes the issue. The real problem is with the design of the FSI engines. Really all of the FSi engines suffer from this issue because there is no washing of valves with fuel to remove the oil, and the inability to keep the oil from getting there in the first place despite a sophisticated catch-can system. For the "most" part, the build up does not cause any misfires. It does however rob the car of 30-40hp! This has been proven with before and after dynos on cars with carbon build up that were cleaned by hand which is a several hour project. Again you can read all about it here:
    http://forums.quattroworld.com/rs4b7/
    Apr 2010
    Colorado
    Quote Originally Posted by toecutter View Post
    Did you have a catback exhaust or did you also have downpipes installed? Usually those fault codes are due to a lack of a primary catalytic converter. The fault you are describing usually occurs when the car is cold, as the primary cat is only used to remove excess emmissions when the car is cold. That is unrelated to a misfire.
  1. Check engine light f/u
    By 2-th-max in forum Maintenance and Service
    Last Post: 07-16-2011, 06:31 AM
  2. check engine light question
    Last Post: 07-01-2011, 07:36 AM
  3. Check Engine Light came on
    By thezman in forum General Discussion
    Last Post: 09-08-2010, 09:37 PM
  4. check engine light
    By esor8 in forum General Discussion
    Last Post: 03-21-2010, 09:24 AM
  5. check the sound of that engine:D:D:D:D:D
    By cooperr8 in forum General Discussion
    Last Post: 02-19-2007, 12:02 AM
