R8 V8 Throttle Opening Max 75%???
Results 1 to 6 of 6
Thread: R8 V8 Throttle Opening Max 75%???
    Mar 2007
    Australia
    Unhappy R8 V8 Throttle Opening Max 75%???
    I have been using the VAGCOM Rosstech tool in OBD-II mode. It allows you to record real-time values of the Engine and Vehicle parameters.
    So, I decided to go for a drive and record Intake Air Temp, Vehicle Speed and Relative Throttle Position.
    To my disappointment I found the Throttle Sensor only opens to 75%!!
    This means my pedal is fully pressed to the floor and NOT ONE value was higher than 75%!
    Could this be true? Is this maybe Audi trying to reduce the performance of the V8? Why hasn't anyone picked this up???
    Check out graph below...
    Re: R8 V8 Throttle Opening Max 75%???
    My sensor goes from 20% at idle - 80% at WOT. This IS full throw of the butterfly. There is an adaptation program in the ECU which runs sutomatically. It 'learns' the range of the TPS on each individual car. Similar to progamming the automatic windows by running them fully up and down.
    Mar 2007
    Australia
    So, in your experience, are you saying the butterfly DOES open FULLY on max throttle?
    I don't have anyway to know for sure, but I think so!
    I think what you are seeing in OBD-II mode is not the throttle position sensor (TPS) on the engine, but instead the input to the computer from the sensor(s) on the gas pedal.
    Mar 2007
    Australia
    Hmmm, ok. Will do some more research and come back to ya!
    Italy
    only Gallardo Lambo and V10 tuned open 100% butterfly
    It's normal!
  8. Remove Advertisements
  1. Throttle response in first gear -- lunging?
    By soho in forum General Discussion
    Last Post: 05-26-2011, 10:14 PM
  2. Replies: 6
    Last Post: 02-15-2010, 11:56 AM
  3. Door/window opening in frosty weather
    By bluesatin in forum General Discussion
    Last Post: 12-19-2009, 08:16 AM
  4. Replies: 10
    Last Post: 07-31-2009, 03:10 AM
  5. Question: reaction to gas/throttle
    By fahren in forum General Discussion
    Last Post: 05-22-2009, 11:48 AM
