what oil should I refill with?
Results 1 to 10 of 20
Thread: what oil should I refill with?
    Mar 2010
    Hi,
    The minimum oil indicator showed up today and I'm wondering what oil I should refill with.
    At my last oil change I saw the service guys put in 10l of 0w40 oil.
    At my 2nd visit to the garage they topped it up with 1l of 0w30.
    From what I understand it's not good to mix two different types?
    Should I refill with 0w40?
    Thanks,
    O
    Senior Member club411's Avatar
    Mar 2010
    Chicago - West Loop
    Re: what oil should I refill with?
    Castrol Syntec 5W-40
    Storm Trooper'd -Mercedes ML63 AMG
    Darth Vader'd AUDI R8
    Jake Ryan'd Porsche 968
    Chun Li'd Ducati Streetfighter 848
    Member postdady's Avatar
    Oct 2008
    NYC, USA
    Same oil for V10 as V8????
    2011 V10
    Daytona Gray
    Aug 2009
    Ottawa, ON, CA
    I just get the oil from the dealer (but from the local VW dealership, because it's cheaper there). Castrol SLX Professional. At least in Canada, it's the cheapest approved oil around, and it's exactly what the dealership here puts in the car. I had a lot of issues trying to find any oil with the right approval on it at the local parts stores, so I just went to VW. Turns out they only charge 8.50$ a liter which isn't that bad at all.
    Senior Member Rit2's Avatar
    Malaysia
    I believe the embossing on the oil filler cap should say CASTROL.
    I used to be bias towards MOBIL 1, but not anymore. I use CASTROL EDGE.
    Check it out at, http://www.changeyouroilchangeyourlife.com/faq2.html
    I read another report, the EDGE was developed for use on the Bugatti Veyron.
    West Wales, UK
    The recommended oil varies by country.
    The UK manual (2008) states that the following should be used in the V8 depending on service type:
    longlife 504 00
    inspection 502 00 / 504 00
    The recommended oil here was originally Castrol SLX Professional Powerflow 5w30 which was replaced by Castrol Edge 5w30
    Q5 3.0 tdi s-tronic
    Mar 2010
    Don't I have to stick to the exact same oil they already put in last time? Is it dangerous to mix w30 with w40?
    Europe
    Use Castrol Edge 5w30 or 5w40 depending on your location. If you tell us where you are we'd be able to tell you which oil is probably already in your car.
    Mar 2010
    I'm in Monaco.
    As I wrote in the initial post I already had 10 l of 0w40 in the car and then they topped it up with 1 litre of 0w30. So I guess I'll continue with 0w40?
    Mar 2010
    I put some shell helix ultra 5w40 in.
    oh la la!
