Engine cuts out at high rpm in third gear
Results 1 to 10 of 14
Thread: Engine cuts out at high rpm in third gear
    Apr 2011
    With approximately 800 miles on my 5.2 Spyder (manual) the while accelerating on the freeway in third gear (approximately 80mph) the engine the car started "bucking" as the engine cut out as if it was starved for fuel. Very unnerving. Happened repeatedly. Anyone out there experience the same issue?
    Member EJCR8's Avatar
    Dec 2008
    Pennsylvania, USA
    Re: Engine cuts out at high rpm in third gear
    Were there any messages from the computer/fault indicators? My car has 170 miles on it and recently went through 2 episodes of ESP fault before the engine light came on...it turned out to be a CAM sensor problem according to them...it seemed to occur around third gear then the car would go into limp mode before idling rough then dying. I just got it back and am hoping that was the problem.
    2011 R8V10 Coupe Daytona Gray
    SoCal
    Is the car fully warmed up when this happens? Until water and oil temps have come up off the pegs, the computer will cut fuel somewhere in the 6k rpm range.
    --- WARNING! Poster never takes anything seriously. No really, I mean it. ---
    Dec 2008
    Twin Cities, Minnesota
    I have seen this if you have it in sport mode and approach redline...even if it is warmed up.
    Arrow Re: Engine cuts out at high rpm in third gear
    Bucking at redline at high speeds sounds scary. My rev limiter comes on SMOOTHLY. Feels as if car just won't go any faster because of a cylinder or two being deprived of any ADDITIONAL fuel. ONLY happens at the track. Certain spot, right in front of the grandstands.(Buttonwillow, Bakersfield, Ca.) Not enough power/or a taller gear would be too slow.
    SoCal
    80 mph in third gear is way below red line in a V10. I'm still guessing the OP should let the car get warm and test again. If it still cuts out, record how many rpm, and does it do the same thing in every gear.
    Senior Member SSIIICK's Avatar
    Boca Raton, FL
    There was a post about this a while back. It is a common issue with the 6-speeds in third gear. I have noticed it as well. You can literally floor the car in third and it will start speeding up, then cut out for a second, and then continue. Trust me, you are not the only one. I will try and find the old thread. Not sure if there is a fix. I just live with it. Does what I'm saying sound like your issue?
    2010 Audi R8 5.2
    Ibis White / Black
    Carbon Fiber Everywhere
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Sep 2010
    Chicagoland area
    I've experienced this as well. Found this thread on it, but it's about doing the same in 2nd gear. I'm pretty sure my car is/was always properly warmed up even when this has happened....
    Fuel shut off at 6000 rpm's in 2nd gear
    Boca Raton, FL
    Quote Originally Posted by NVRL8R8 View Post
    Thanks Tommy! That's what I was talking about. I'm pretty sure mine is third gear, but I honestly can't remember (and it even happened today!). Wow, my memory sucks right now (it is 12:17 a.m. and I am tired!!!). Lol! Will try it tomorrow and figure out exactly what gear it happens in. I'm pretty sure it is somewhere between 3,000 and 5,000 rpms if I remember correctly. Let you know tomorrow for sure.
    2010 Audi R8 5.2
    Ibis White / Black
    2009 Nissan GTR
    Black / Gray
    Too Many Mods
    Sep 2010
    Chicagoland area
    Here it is, although it states it happens at lower RPM's. Which I believe is the same in my case.
    ECU Acceleration Anomaly
  1. R8 High Mileage
    By jeffgrice in forum General Discussion
    Last Post: 09-06-2011, 01:39 AM
  2. Engine hesitation at 3k revs in 3rd gear?
    By pike98 in forum General Discussion
    Last Post: 03-02-2011, 10:20 AM
  3. Both V10 and V8 same HIGH Comp.ratio
    By harrison in forum Performance Modifications
    Last Post: 05-31-2009, 08:32 PM
  4. Replies: 1
    Last Post: 01-16-2009, 10:42 AM
  5. High Engine Note after Start up
    By N1JEE in forum General Discussion
    Last Post: 09-24-2007, 02:52 PM
