Hi,
Recently I stumbled upon a nifty little program called Torque, it runs on Android devices and can do a bunch of cool stuff with the car's OBD port like reading, displaying and logging all sorts of vital parameters about your runs (revs, speed, throttle, coolant temp, acceleration, lap times, etc). It can read system error codes, clear them. It supports multiple vehicle "profiles" and more.
This is a fun toy for anyone with an R8 or any other car with an OBD II compatible port. It seems to be a great data logger for track use as well. Logged data can later be overlayed on a track map, or a video taken from the car...
The software: http://torque-bhp.com/wiki/Main_Page
The hardware: http://www.dealextreme.com/p/elm327-...r-dongle-16921
I went for this dongle, not the cheapest on this site, but due to its good reviews and tiny size. It's completely unobtrusive and can therefore be kept always plugged in for added convenience.
Side note, it can be potentially dangerous to always keep it plugged in as other people around with bluetooth devices may read the data at any time and even make changes to your car's computer...no security is implemented. If this is a concern whatsoever, just plug it in when you want to use it.
All you need to do is plug in the bluetooth dongle into the OBD port and start the program up. Setup was literally plug and play with zero hassles.
This dongle can be used with other software as well as it is simply a serial port over bluetooth, hooked up to the OBD port, so it may work with VCDS and others to some degree. I haven't looked into that yet.
I cannot yet attest to the reliability of the dongle. I've read that some are more reliable than others. I'll post a followup if I encounter any problems but so far so good!
Have fun!
LinkBack URL
About LinkBacks
Reply
