Vag com - front led??
Results 1 to 3 of 3
Thread: Vag com - front led??
    Jan 2011
    COLUMBUS OH
    I have an 2009 R8 V8 and had a question with the VAG COM. I just noticed today that when the lights are in OFF position the LED is at full bright. When it's on Auto...well it's auto. Then the switch before the manual headlight function, I thought the LED's were on full bright in that position, but they are not. Does anyone know if there is a way to have the LED's on full bright when in that mode (between auto and headlight on)??
    Mar 2011
    Maastricht, Netherlands
    Re: Vag com - front led??
    The position you are referring to is for the "side lights". They are dimmer in this position because you are meant to set the dial to this setting during dusk or dawn, and where there is no need for full headlights. They are dimmer than the DRL's because they would be too bright in twilight. DRL's need to be brighter because they are on during the day.
    If you want full brightness then why not just leave it in the "OFF" position?
    Jan 2011
    COLUMBUS OH
    Quote Originally Posted by mofomat View Post
    I would do that but I also want my rear tail lights working also during dusk times.
  1. front width?
    By dpe_g35 in forum General Discussion
    Last Post: 06-12-2011, 04:54 AM
  2. Front Rim
    By ACSELR8 in forum Want To Buy - Parts
    Last Post: 06-02-2011, 07:18 AM
  3. 265 on the front??
    By harrison in forum Wheel and Tire Discussion
    Last Post: 05-25-2010, 08:18 PM
  4. R8 Front-end Lift
    By NASA R8 in forum Appearance / Body Modifications
    Last Post: 10-23-2009, 09:16 AM
  5. Front Fog lamps?
    Last Post: 03-21-2009, 11:57 AM
