SD Card Slot
Results 1 to 7 of 7
Thread: SD Card Slot
    Member hblocal's Avatar
    Sep 2011
    Los Angeles
    SD Card Slot
    On the older (08-09) model R8's can the SD slot read a card that's more than 2GB? The manual I think says it can only take 2GB but just wondering if maybe anyone has tried a 4gb or 8gb card? The newer R8's can handle 8gb I heard? What year did this change happen?
    2009 Audi R8 4.2
    2011 AW BMW M3 ZCP
    2010 Toyota Prius IV
    2009 Maserati Granturismo..gone
    2005 MB E55 AMG..gone
    2005 Porsche Cayenne Turbo..gone
    2001 911 Carrera 4..gone
    Senior Member guod's Avatar
    Apr 2011
    Toronto, Canada
    Re: SD Card Slot
    Quote Originally Posted by hblocal View Post
    I think the difference is that the newer models can use SDHC cards. These cards are usually 4GB+
    However, you can find a 4GB SD (non-HC) card possibly ebay etc.
    I think the changeover occurred on 2010MY but not 100% sure.
    Edit: I think there is also a file count limit so having a larger card may not make a difference
    Sep 2011
    Los Angeles
    Re: SD Card Slot
    very helpful thank you
    2009 Audi R8 4.2
    2011 AW BMW M3 ZCP
    Aug 2011
    California
    Re: SD Card Slot
    Newer SDHC cards are backward-compatible with SD cards. That is, you "should" be able to plug SDHC cards in and they should work. However, they will likely show up as 2GB only. The rest falls into some sort of black hole. Of course, compatibility is relative. It could easily be that only some cards really are backward compatible.
    NB: This is uninformed with regard to R8's specifically.
    Europe
    Re: SD Card Slot
    I tried several different SDHC cards with my 2009 nav and none worked, as in, the unit would not be able to read them at all.
    I then bought 4GB SD cards off amazon, which worked. I then went and upgraded my nav unit and now use SDHC cards in it.
    Apr 2011
    Toronto, Canada
    Re: SD Card Slot
    Quote Originally Posted by zondar View Post
    I've never heard of this before - I had a few SD card readers i..e my monitor from dell and none of them worked with the newer SDHC cards at all. I wish they made them backward compataible somehow!!
    Apr 2008
    Re: SD Card Slot
    You can use 4GB if its SD (not SDHC). I bought these off of Amazon UK and they work:
    Platinum 177106 Secure Digital 4 GB SD Card
    [ame="http://www.amazon.co.uk/gp/product/B000BR9ZRG"]Platinum 177106 Secure Digital 4 GB SD Card: Bestmedia: Amazon.co.uk: Computers & Accessories[/ame]
  9. Remove Advertisements
  1. Can SD Slot read folders?
    By hblocal in forum General Discussion
    Last Post: 04-13-2012, 06:11 PM
  2. SD slot, where is it?
    By pissmop in forum General Discussion
    Last Post: 04-29-2010, 04:08 PM
  3. Spyder slot sells on E Bay!
    By Monkey boy UK in forum General Discussion
    Last Post: 11-22-2009, 10:43 PM
  4. V10 Slot
    By AmexBlackG5 in forum General Discussion
    Last Post: 08-11-2008, 11:53 AM
  5. R8 build slot on eBay
    By Paul in forum General Discussion
    Last Post: 12-11-2006, 08:16 AM
