Converting the rear turn signals...
Results 1 to 9 of 9
Thread: Converting the rear turn signals...
    v10
    v10 is offline
    Senior Member v10's Avatar
    Jul 2011
    ()Arizona (x)Germany
    I thought I remember seeing a thread about this but I searched and couldn't find it. Has anyone converted the rear turn signals on a US spec R8 to the Euro style? US spec cars flash the tail lights, whereas the Euro cars flash the thin clear horizontal stripe beneath the tail lights.
    It looks like the US cars have the rear lens but I'm not sure if there is a bulb in it.
    2011 Audi R8 5.2 FSI
    2010 Dodge Viper ACR - sold
    2010 Corvette ZR1 - sold
    Re: Converting the rear turn signals...
    Yes and no.
    If your car's wire harness has six wires going into the plug that runs the tail lights (what I believe my 09 V8 has, but have not checked), it's fairly easy and straight forward. If it only has 5 (as my 2011 V8 does), then no. And yes, is sucks having Euro spec GT tail lights in my car and NOT being able to isolate and use the amber blinker. (insert appropriate swearing here)
    If your wire harness is correct, all you have to do is use a Ross-Tech system and reprogram the rear tails - I can't recall the exact module, but it was easy.
    The US spec cars do NOT have the LED turn signal strip. You MUST have Euro spec tail lights for the amber blinker strip to be available.
    fwiw: six wires out of the Euro spec tail lights are:
    reverse power
    reverse ground
    tail ground
    brake light power
    tail light power
    turn signal power
    v10
    v10 is offline
    Jul 2011
    Yes and no.
    reverse power
    reverse ground
    tail ground
    brake light power
    tail light power
    turn signal power
    Thanks for the info. Where is the wire harness located?
    Easiest access to the harness is by removing the inner fender liners. Wheel has to come off too. Once that's out of the way, you'll be able see where the wire harness and plug go into the back of the light ass'y.
    Member elvis692's Avatar
    Apr 2011
    Lake Forest, CA
    I had it done to mine at oemplus. Looks great and i get compliments all the time too
    Quote Originally Posted by elvis692 View Post
    I have it on my 09 - and yea, it looks great. The problem is that it appears that Audi's changed the wire harness for newer year model vehicles and w/o that 6th wire, well... Magic's gonna have to happen to make it work.
    v10
    v10 is offline
    Jul 2011
    I find it odd that thin amber strip doesn't mean US requirements for turn signals but a flashing tail light does. The amber strip is more noticeable IMO... especially with the hazard lights on.
    I'm taking my car to a German dealer soon, I will have them look into converting the signals if possible.
    I believe that it's Audi's choice here more than dedicated by the US DOT.
    Think about it - you see both types of brake/tail/turn systems on vehicles here. Toyota pickups (maybe older models, not sure of the new ones), for example, have the separate turn signal, while Ford runs a setup like a US market R8 (brake lights double as signal).
    I agree - the separate signal strip is much more visible and (at least in my eyes) more aesthetically pleasing.
    Aug 2009
    Ottawa, ON, CA
    Can somebody look at ETKA and find out when the production date changed for the differences in the wire count to rear harness to the taillights?
  11. Remove Advertisements
  1. Cant turn off ESP
    By wer1331 in forum General Discussion
    Last Post: 05-04-2012, 07:35 AM
  2. Converting V8 to V10 rear bumper
    By RS4Cab in forum Appearance / Body Modifications
    Last Post: 07-20-2011, 11:46 AM
  3. Do the V10 LED DRL's turn off when turn signal on?
    By peterh in forum General Discussion
    Last Post: 04-03-2011, 07:43 AM
  4. How do I go about converting my R8 to stealth ?
    By Rob A in forum General Discussion
    Last Post: 10-24-2008, 12:11 PM
  5. my turn now...
    By R8chris in forum General Discussion
    Last Post: 08-03-2007, 12:08 AM
