I have an older V8 so I used the Tunerdome bulbs and so far no codes thrown. I wasn't planning on posting this since I figured it was rather easy so I didn't take step by step pictures. But I took a couple pictures just in case anyone was going to do this.
Under the door you'll see the light housing is not held by any screws like the trunk/license plate led in the back. That's about the only tricky part of this install. The screws on the trunk led make install self explanatory but the lights under the doors take a little effort to pull out of the door.
You have to pull the light towards the front of the car while also pulling down on the housing. It's pretty snug btw. Then you remove the half circular plastic black cap that covers the bulb housing and unclip the wire harness from the bulb housing. Pull the bulb out and replace with the Tunerdome wedge led bulb and clip it back on. It's that easy.
I also included a pic of my trunk license plate led's installed with Tunerdome bulbs. No code here so far either. It was still daylight out so I didn't have the chance to take pictures of how bright the leds are at night. The license plate led lights seem to not be very bright though. Hardly can see the plate numbers (which is a good thing I suppose) but I thought it would be brighter like from the factory on some BMW's and Lexus. The under door led bulbs seem to glow much brighter than the license plate bulbs for some reason.
Here are some pics along the way.
LinkBack URL
About LinkBacks
Reply
