Top Cars Braking Under 100 Feet
Results 1 to 6 of 6
Thread: Top Cars Braking Under 100 Feet
    Senior Member gazza1's Avatar
    Australia
    R8 V10 IBIS WHITE SPYDER
    R8 V8 IBIS WHITE COUPE
    NISSAN GTR R35
    Life Is Full Of Surprises.
    Jan 2011
    NorCal River Delta
    Re: Top Cars Braking Under 100 Feet
    Impressive list......
    Senior Member RS4Cab's Avatar
    North of Boston, MA
    So why waste money on ceramic brakes? Seems unless you track often the stock brakes will do just fine
    Oct 2011
    Essex, UK
    Ceramics will allow you to spend more time on track without fade from overheating (if your tyre pressures allow) and will last longer (Rotors up to 250k Miles and pads on average 4 x longer), side by side there is nothing in the performance of stock steel v CER, I have attended an Audi invitational R8 day and taken part in a test session to prove just this.
    R8 V10 Coupe, R-Tronic in Ibis White - ALL the CF and Capristo Exhaust.
    Europe
    According to desperado from a thread briefly discussing ceramic brakes a few days ago:
    "While the Brembo carbon ceramic brakes (CCB) stop great and are very fade resistant, they are not a lifetime piece of equipment. The pads do need regular inspection and replacement. And the discs wear, too. That's why there is a minimum thickness and minimum weight specification shown on each rotor's aluminum bell (hub).
    I have the Brembo CCB on my Corvette, and the pads were completely done at 7,500 miles! Of course there were a number of track days in there but the point is still valid - even if you don't track the car the pads do experience wear. It doesn't help any that the ceramic pads on the CCB start out thinner (only 3/8") than those on the standard brakes. I'm told to expect the discs to need replacing about every two to three sets of brake pads depending on how hard they are used."
    May 2011
    That's impressive.
  8. Remove Advertisements
  1. Steering wheel vibrating when braking
    By M3R8 in forum Maintenance and Service
    Last Post: 11-07-2011, 10:34 AM
  2. Braking problem
    By fabiopanasiti in forum Maintenance and Service
    Last Post: 09-29-2011, 01:16 PM
  3. ONLY TWO feet of snow !!!
    Last Post: 12-31-2010, 05:11 PM
  4. Are my feet too big ??
    Last Post: 10-09-2010, 09:42 AM
  5. Ceramic system BRaking
    By _pax0dt0_ in forum Wheel and Tire Discussion
    Last Post: 05-21-2010, 03:06 PM
