Disconnect exhaust valve, so always open?
Page 1 of 29 123411 ... LastLast
Results 1 to 10 of 284
Thread: Disconnect exhaust valve, so always open?
    Senior Member Bodhii's Avatar
    MountainWest USA
    Any way to disconnect the exhaust valve on R8 so its always open?
    Senior Member Ti-Mike's Avatar
    Aug 2007
    + Switzerland
    Re: Disconnect exhaust valve, so always open?
    you can reach them by just lifting the rear end of the car, just pull the rubber tubes out and push a allen no 5 size screw into the rubber tube do not leave the tube open.
    Or you dismout the inner cover of the rear wheel and you find a alloy tube with a rubber connector , just do the same work there.
    You have to this work on both sides.
    greetings from Lugano
    MIKE
    Mar 2007
    Australia
    Thats garbage. You need an R8 tech who knows his stuff. My tech works on Lambos as well. He disconnected the Vacuum hose under each rear wheel guard as descibed by Ti-Mike. All is perfect. No engine check light and it sounds like a WEAPON!!
    MountainWest USA
    Bz888, thanks for the info.
    May 2007
    The trick is to bung the end of the vacume pipes, otherwise the check engine light will come on.
    Nov 2007
    Moray Firth
    A golf tee stuck in the pipe with a jubilee clip securing it will do the trick
    Its here Born 1/5/08
    Mar 2007
    Australia
    Quote Originally Posted by r8rob View Post
    Correct.
    MountainWest USA
    Works great. Most easy and effective mod I have ever done. I love the sound now, at all RPM's
    Mar 2007
    Australia
    Quote Originally Posted by Bodhii View Post
    Good work mate. If you've got the R-Tronic, you can make it spit and crackle between shifts! Sounds awesome.
    Dec 2007
    Seoul, Korea
    800, Wanna do this?
  1. Disconnect exhaust valve, so always open?
    By Bodhii in forum Performance Modifications
    Last Post: 08-01-2011, 08:31 PM
  2. Exhaust valve disconnect on Spyder
    By Greg P in forum Performance Modifications
    Last Post: 06-21-2011, 11:32 AM
  3. PPI no valve exhaust (help with video or sound)!!!
    By Black Eagle in forum Performance Modifications
    Last Post: 11-26-2008, 09:22 PM
  4. Exhaust valve on/off video comparison
    By Black Eagle in forum Exhaust Systems
    Last Post: 06-03-2008, 11:31 AM
  5. Exhaust valve on/off video comparison
