B7 RS4 Front Disc's
Results 1 to 5 of 5
Thread: B7 RS4 Front Disc's
    Jul 2008
    B7 RS4 Front Disc's
    Hi there. First post, hope I'm not asking a stupid question...
    Can the B7 RS4 floating disc's be fitted on an R8? The diameter and disc thickness are the same but I don't know if the offset is.
    TIA
    Senior Member Ti-Mike's Avatar
    Aug 2007
    + Switzerland
    Re: B7 RS4 Front Disc's
    but they have less ventilation i would not mount them
    greetings from Lugano
    MIKE
    Jul 2008
    What do you mean by less ventilation?
    Aug 2007
    + Switzerland
    look at both disks and you'll see the differents
    MIKE
    Jul 2008
    Brembo has them available in a larger diameter with new caliper mounts. If not then you can call APR.
  7. Remove Advertisements
  1. Vag com - front led??
    By JAMESY1010 in forum General Discussion
    Last Post: 08-13-2011, 09:44 AM
  2. Front Rim
    By ACSELR8 in forum Want To Buy - Parts
    Last Post: 06-02-2011, 08:18 AM
  3. 265 on the front??
    By harrison in forum Wheel and Tire Discussion
    Last Post: 05-25-2010, 09:18 PM
  4. R8 Front-end Lift
    By NASA R8 in forum Appearance / Body Modifications
    Last Post: 10-23-2009, 10:16 AM
  5. Front Fog lamps?
    Last Post: 03-21-2009, 12:57 PM
