PPI Audi R8 Razor @ Essen Motor Show
Results 1 to 10 of 11
Thread: PPI Audi R8 Razor @ Essen Motor Show
    Senior Member Bodhii's Avatar
    MountainWest USA
    Here:
    World premiere of the PPI RAZOR GTR at the 2008 Essen Motor Show
    November 19, 2008 - Courtesy of PPI Automotive Design
    The all-new PPI RAZOR GTR limited production Supercar -
    Intense driving pleasure in a strikingly bold design.
    * More POWER
    * More STYLE
    * More PASSION
    The Exclusive German Audi-tuner, PPI Automotive Design GmbH intensifies the fire and presents the special limited production Supercar, the PPI RAZOR GTR.
    Performance
    Following the introduction of the wildly successful PPI R8 RAZOR at last year's Essen Motor Show, PPI Automotive Design GmbH have used all its knowledge from the past year in competition, closed road races, open road races, and research and development in the wind channel, autobahn and track testing, to create a truly inspired production car. The Audi specialist turned its focus on optimizing the power-to-weight ratio of the Audi R8 while simultaneously strengthening the motor, increasing performance, improving handling dynamics, and managing to reduce the weight of the Audi R8.
    The essential part of the motor alteration is the incorporation of a specially engineered supercharger. In addition, a ram-charged sport air filter system and a high performance exhaust system made of stainless steel have been designed and added specifically to work in conjunction with the supercharger system. These components are precisely adjusted to each other with the help of a new ignition map for motor electronics.
    The result, after this extensive modification, is a car with 580 hp / 427 kW at 7,400 rpm, a maximum torque of 600 Nm at 6,200 rpm at its disposal, and a weight decrease of 250 kg over its serial counterpart (serial curb weight 1,580 kg). Providing the PPI RAZOR GTR with the ability to achieve speeds from 0 to 100 km/h in only 3.7 seconds with a maximum top speed of 332 km/h. This insures the proper performance to easily meet the demands of its motorsports and enthusiast clientele.
    Aerodynamics
    In addition to the excellent driving performance, this PPI Supercar also has a striking widebody appearance with elaborate, wind tunnel tested aerodynamics. Special attention was paid to the reduction of the vehicle's weight, which was achieved by PPI's extensive use of the extremely light and high-strength formula 1 and aerospace-proven Carbon Fibre. All parts are made of this high-tech material, reducing weight and adding strength in the process.
    The PPI RAZOR GTR front bumper replaces the serial bumper and the new design in conjunction with a specially engineered front diffuser, reduces lifting forces at the front axle. Larger air inlets in connection with a new full LED-headlight unit present the two-seater with an even more athletic face. More importantly, these air inlets feed the radiators with additional fresh air and channels through the new front hood to provide optimal cooling to the brake system. PPI sideskirts highlight the sporty profile of the GTR and also diffuses the airflow around the sides of the car for improved aerodynamic stability.
    In order to perfectly balance out the down-force behavior of the front-axle with the rear axle, PPI equips the RAZOR GTR with a special rear wing with an adjustable Gurney-flap. The motor cover, made of the light high-tech polycarbonate material Makrolon®, also has specially designed Carbon Fibre ram-charged air inlets that replace the heavy OEM Engine cover and aid in cooling, ensuring the consistent performance of the RAZOR GTR. Aiding in the engine cooling, are the newly designed side blades, rear fenders and rear bumper allow for additional motor bay and exhaust cooling that, in conjunction with the Carbon Fibre rear diffuser, optimizes the airflow over and through the rear portion of this sharp performance car.
    Handling
    The overall appearance of the car is further enhanced by a new widebody skin to allow the PPI RAZOR GTR the proper structure to accommodate all the performance enhancements and wider wheels. The RAZOR GTR utilizes specially designed lightweight MAG11 forged PPI wheels. At the front, 10Jx19 MAG11 wheels with 255/35 ZR 19 Michelin Pilot Sport 2 tyres are fitted and an impressive 11.5J x 20 MAG11 wheels with 325/25 ZR 20 Michelin Pilot Sport 2 tires are used at the rear. This wheel and tyre-combination proves to be the optimal balance between comfort and control while maintaining proper road feedback for the driver.
    PPI also developed a special high-performance braking system available only for the RAZOR GTR that can be identified by its metallic orange-colored brake callipers. The optimal deceleration and perfect pedal pressure control is now achieved by enlarged 6-piston calipers in connection with extra-large discs measuring 380 x 36 millimeters at the front and 356 x 32 mm discs at the rear axle providing greater pad surface contact area and heat dissipation.
    Nothing has been left untouched, as is evidenced by the new coil over kit developed in conjunction with technology partner KW Automotive GmbH. This system has been specially adjusted to the needs of the PPI RAZOR GTR. And comes equipped with a Hydraulic Lift System, which can increase ground clearance by up to 45 millimeters if needed and therefore enables the driver to enter underground car parks or drive over speed bumps.
    Interior "Performance"
    PPI completely re-designs the interior and turns the R8-interior into a "members-only" lounge with a motorsports flair. The serial interior is replaced by highest quality Onyx Nubuck-leather with orange-colored accents and highlights. Additionally, PPI equips the limited edition RAZOR GTR with extensive Carbon Fibre throughout the ****pit; hand-brake lever, door sill protectors, Driver and Radio Console Surround, Door Trims, Center Console inserts, and kneepad trims, the ultra-light folding sport seats are also made of Carbon Fibre and bear the PPI "Sport Identity" style, following with the headliner, the steering wheel, shift knob, door panels and center console. The technical highlight of the interior is the ergonomically re-designed PPI sport steering wheel. Highlighting the exclusivity of this limited series production is PPI RAZOR GTR badging, threshold plates, and an aluminum production plaque framed by Carbon Fibre.
    The new PPI RAZOR GTR Supercar…. BOLD Design, SHARP performance, and EXCLUSIVE production, developed and presented by PPI Automotive Design GmbH, the only tuners for Audi automobiles with a true focus on "Engineering in Style."
    SEAT of the PANTS DYNO
    Oct 2008
    Re: PPI Audi R8 Razor @ Essen Motor Show
    Sorry but that has got to be the ugliest R8 mod car I've seen to date! For the love of God, why not leave it as it is?!
    Senior Member 09R8's Avatar
    Los Altos, CA
    I have to agree with others here. I highly doubt they would sell many of these. Although looks are subjective, there is a general agreement on hacking up a very refined car
    '11 Rosso 458 Italia
    '05 Black Carrera GT
    '10 DG R8 V10
    *Sold
    '08 ClK63 BS
    '04 Gallardo E-gear
    '03 Rosso Corsa 360 Modena
    '07 RS4
    '06 RR Supercharged
    MountainWest USA
    Here is an updated version of the PPI Audi R8 Razor GTR
    This is is still my idea of the ULTIMATE R8.
    Following the unveiling of the original ‘Razor’ Audi R8 at the Essen Motor Show last year, German tuning firm PPI Automotive Design GmbH has unveiled an even more aggressive version of the car that it debuted late last month at the Top Marques Motor Show in Monaco.
    Picking up the ‘GTR’ designation, the latest model builds on the success of the original version using knowledge PPI engineers have gathered over the past year from racing, wind tunnel development, and autobahn and track testing. The highlight of the package is an increased focus on optimising the power-to-weight ratio of the Audi R8, with engineers simultaneously boosting power while reducing weight.
    The essential part of the motor alteration is the incorporation of a specially engineered supercharger. A ram-charged sport air filter system and a high performance exhaust system made of stainless steel have also been designed and added specifically to work in conjunction with this new forced-induction system.
    The end result is a car with 580hp (427kW) and 600Nm of torque. At the same time, the R8’s 1,580kg kerb weight has been reduced by more than 250kg, enabling the Razor GTR to accelerate from 0 to 100km/h in only 3.7 seconds and reach a top speed of 332km/h.
    In addition to the improved speed performance, the car also has a striking widebody appearance with elaborate, wind tunnel tested aerodynamics. All the parts, including the new front bumper, diffuser, side skirts, and hood, are made from carbon-fiber.
    Handling has been improved with the addition extra-wide 19in forged alloy wheels wrapped with 325mm Michelin Pilot Sport 2 tires in the rear and 255mm sets up front. Sitting within these is an updated brake package with six-piston calipers all around and 380mm discs up front and 356mm units in the rear. The final mod is a hydraulically adjustable suspension kit developed together with KW Automotive.
    Mar 2007
    Australia
    Awesome!!! Where can we buy the parts?
    MountainWest USA
    This is all that PPI offers as separate after market parts, and they are expensive. PPI's intention is to get buyers for the complete conversion. Wish I had the extra bucks for such stuff.! That is really an amazing car.
    http://oempl.us/index.php?main_page=...roducts_id=597
    My biggest love of this PPI Razor GTR R8 is the great interior even with loosing 250KG!! The only way to do that I guess is with a total PPI Razor GTR conversion. Hey BZ888, they already have this orange trim interior setup for your R8!
    I have a full PPI price list as a .PDF but it's too big to post. perhaps we could push for a group buy - the Radio surround is a must (for me) if you have the Carbon Sigma interior, the 'micrometallic grey' surround looks cheap and nasty to me. I guess as you can get the radio surround in Audi Exclusive leather you could be it from your friendly Audi dealer, I'll get a price and report.
    Best Regards, Ian
    Mar 2007
    Australia
    Here's my wish list:
    PPI Stage II Front Bumper and Splitter
    PPI Stage II Adjustable Rear Spoiler
    LMS Front Bonnet
    LMS Polycarbonate Engine Cover
    V10 Side Blades
    Would love to know how they lost 250KG!!!
    Senior Member SDR8's Avatar
    San Diego, CA
    The new picts of the white GTR car have the new HRE carbon wheels. I just stopped by their shop today and saw the wheels in person. They are offering two aluminum centers in a variety of colors on 19" & 20" dymag carbon rims. Very nice. Those are the first set of those wheels from HRE. They have some pre-orders on them, but they should be available this summer.
    Dec 2007
    Seoul, Korea
    With that rear spoiler, does the original rear wing get disabled?
  1. Top 10 Cars of the Tokyo Motor Show
    By AutoGuide.com in forum Off Topic Discussions
    Last Post: 12-02-2011, 12:57 PM
  2. 2011 Tokyo Motor Show Coverage
    Last Post: 11-28-2011, 12:57 PM
  3. Fs: Audi r8 v8 ppi razor
    By technomania in forum For Sale - Vehicles
    Last Post: 09-26-2011, 01:50 PM
  4. Audi R8 PPI Razor GTR ??
    By ttyl in forum Appearance / Body Modifications
    Last Post: 03-07-2011, 07:48 AM
