Hi all,
As an official Brembo brake outlet in the UK, we now stock the Brembo brake disc upgrade for the R8.
The kit is for the front only and includes:-
- Brembo 380mm x 34mm two piece front disc, available drilled or slotted
- Brembo brake calliper carrier
- Brembo brake fluid
- Option of OEM new front pads or selection of Pagid pads
A couple of pictures of this kit recently installed to a B7 RS4:-
Some of the main benefits of this setup over stock are:-
- Larger surface area aids in dissipation of heat
- Slotted discs available for track biased use
- Disc material has high carbon cast iron construction to increase thermal capacity and offer better friction properties
- Curved vane venting that offers better cooling than stock discs
- Thicker disc wall allowing disc to act as more efficient heat sink
We offer this kit along with high performance Brembo brake fluid upgrade for £1699 INC VAT fitted.
For any further information please do not hesitate to contact me,
Kind regards,
Ed Jackson
LinkBack URL
About LinkBacks
Reply
