How to eliminate/reduce understeer at track?
Results 1 to 9 of 9
Thread: How to eliminate/reduce understeer at track?
    Jul 2010
    2010 R8 V10.
    I tracked it with OEM Pirellis, then switched to 245 front/305 rear Bridgestone RE11's.
    Lots of tire shredding understeer with the Pirellis, better, but still understeers with the RE11's.
    I plan on giving it more negative camber in the front.
    Any other experiences or suggestions? Anyone know the OEM camber spec, and have any tried and true track settings?
    Re: How to eliminate/reduce understeer at track?
    Quote Originally Posted by thunder View Post
    2010 R8 V10.
    Turn off the TC and the Audi programmed understeer should turn into power induced oversteer.
    Best Regards, Ian
    Arrow Re: How to eliminate/reduce understeer at track?
    At the track, and on the edge, on high speed sweepers , the rear end always gives out first. This is with 235-315 Hoosiers.This is with the TC off of course. Next rears will be 325 Hoosier. My tires and brakes wear quite evenly.What a beautifull set-up. Mess with your camber and let us all know how many seconds you shave off of your lap times Bro.
    Apr 2008
    USA
    I reduce the tire pressure in the fronts to 36 PSI (to match the rears), and that makes it very well balanced, at least in my car. I have the H&R springs and have maxed out the front camber and run Hoosier R6's at the track.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Jul 2010
    Quote Originally Posted by MotherTucker View Post
    mt
    Is the 36 psi pressure hot or cold?
    Supporting Vendor
    Dec 2009
    Oakland, CA
    Well first obvious move, which I assume you do on track, TC off. I can't even drive on track with any of this junk on, completely invasive.
    Second, look at tire pressures. As suggested you may want to alter front/rear tire pressures.
    Take a peak here:
    http://www.tirerack.com/tires/tirete....jsp?techid=58
    If you are going to move to a more aggressive alignment, max front negative camber, zero toe with factory rear camber and factory toe-in style rear alignment.
    Increase your front traction, fit the widest tire you can up front.
    Lots of methods to play with and I'd likely start with tire pressures and alter 1-2lbs per sessions (cold) to see how it makes the car behave. If pressures can't overcome the understeer issue take a look at alignment and tire choice. Also make certain you are entering corners at the proper speed for that specific corner with your setup. Coming in like a lamb and out like a lion can still apply even to an R8 and use some of that power to overwhelm the rear traction if you feel understeer coming power-on out of the corner.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    contact@europrice.us
    Follow Europrice on Facebook
    Apr 2008
    USA
    HOT. That's critically important, as the cold pressure will go up by 6 to 10 PSI at least, depending on how hot the weather is and how hot you get the brakes.
    I put 32 in all 4 tires in the morning, and then right after the first session, check the pressures and bleed off excess pressure to get to 36 all around. That works really well for me.
    mt
    2007 VW GTI MK5
    1992 Acura NSX
    Oct 2007
    Kuwait
    SLOW DOWN !!!!!! ...........just kidding :P
    Quote Originally Posted by biggie27 View Post
    Actually, that was my immediate thought also. Slow in, fast out.
    I also agree with 36 hot when running the R6. I ended up there after trying higher pressures but they just didn't work well with the limited negative camber available in the car. Again, this is for the R6.
  11. Remove Advertisements
  1. How to reduce weight of R8 V8
    By Reddy in forum Performance Modifications
    Last Post: 09-14-2011, 03:28 PM
  2. Arizona to eliminate DPS speed-enforcement cameras
    By R84ME in forum General Discussion
    Last Post: 05-08-2010, 02:27 PM
  3. track day!
    By trincap in forum General Discussion
    Last Post: 10-24-2009, 05:45 AM
  4. First Track Day - Video (Track Warriors Please Ignore)
    By utah in forum General Discussion
    Last Post: 10-10-2008, 09:40 AM
