* MTM at the Autosalon 2011 in Geneva - hall 5 / booth no. 5140
* World premiere: Polished MTM R8 Biturbo - more than 1.200 working hours
* MTM TT RS with 472 hp / 347 kW
MTM from Wettstetten will be represented at the Autosalon in Geneva from the 3. - 13. March 2011 with two cars. In hall 5 MTM, car manufacturer and upgrading specialist, presents not only technical details and masterstrokes but also a visual highlight, which lets the exhibition hall shine in the truest sense of the word. The MTM R8 Biturbo with 777 hp / 571 kW and a top speed of more than 350 km/h was highly polished by MTM , this unique specimen with a worth of over 400.000 € was depainted completely in a special procedure and the aluminium chassis was polished in more than 700 working hours - all handmade . As well to see at the Autosalon: the MTM TT RS in the MTM design with 472 hp / 347 kW, which reached a top speed of 312 km/h at first test drives in Nardo.
MTM R8 V10 BiTurbo
The details of the highly polished MTM R8 V10 Biturbo, for which MTM also promises a registration for Germany: Performance upgrade to 777 hp, 888 Nm torque and a top speed beyond the 350 km/h. MTM also expects best acceleration values:
0 - 100 in 3,0 sec
0 - 200 in 9,37 sec
0 - 300 in 19,42 sec
The test drives on the highspeed track in Nardo in South Italy in September last year showed that the car can be moved in a sporty way also under extreme conditions, full load drives and extreme temperatures. MTM uses a coil over kit with adjustable suspensions, 20" forged rims in the Bimoto design and MTM brakes 380 x 34 mm dimpled with 8-piston calipers at the front and rear axle.
The V10 Biturbo engine was already tested successfully in the RS6 with up to 740 hp / 544 kW and a top speed of 362,5 km/h in Nardo.
Real uniqueness you can also find at the design: The paint of the R8 was completely removed and highly polished in over 700 working hours. The plastic attaching parts have been replaced by carbon parts or with a special paint polished. An adjustable rear spoiler and a front lip out of carbon improve the aerodynamic and stabilise the car. The interieur leather shows that MTM Individual has a perfect design.
MTM TT RS
Power output (max.): 472 hp (347 kW) at 7000 rpm
Torque (max.): 600 Nm at 4400 rpm
Acceleration 0-100 km/h: 3,9 s
Top speed: 312 km/h
Brakes: MTM brake VA 380 x 34mm, dimpled, 8-piston calipers
Wheels: 20'' MTM Schmiederad im BIMOTO Design
Price: 84.166 Euro (incl. tax and installation)
