Has anyone actually installed this PPI Roll Bar???
We are having issues.
Installation instructions read as per below:
12) With bar still in place, use upper mount holes as guide to drill 3/8" holes
through rear firewall. Note that firewall is twin-walled so use care to keep
bit straight and penetrate both walls
13) From engine compartment, use Uni-bit to enlarge holes to 3/4" ON
ENGINE COMPARTMENT WALL ONLY. This is to allow aluminum spacers
to be installed
14) Install upper-plates in engine compartment (see photo for proper
hardware placement)
Issue is with Point 12. The section of the firewall which lines up with the mounting plate is actually single wall and not dual wall! See picture below.
Therefore, since it's single wall we need to consider the following:
1. Why did PPI provide Spacers, when the actual position of penetration into the firewall, is a Single Wall only?
2. If PPI expects the roll bar firewall plate to line up the box section in yellow which is dual wall, then they obviously have never installed one. It's impossible!
So, we have to stop work until we clarify this issue with PPI USA or OEMPlus.
Anyone installed before? Any assistance would be great!
LinkBack URL
About LinkBacks
Reply
