How does more camber affect highway tracking?
Results 1 to 8 of 8
Thread: How does more camber affect highway tracking?
    Senior Member SteveR's Avatar
    Jan 2009
    Michigan
    I am seeing a little more outside wear on the front tires and am thinking of more negative camber for the front. I don't plan to get a camber kit, so I know the adjustment range is limited. Should I just have them max it out? If I do, will it cause any wandering with highway driving?
    Garage: R8 S4 | gallery
    Supporting Vendor
    Dec 2009
    Oakland, CA
    Re: How does more camber affect highway tracking?
    If you drive particularly hard or track the car probably just max any adjustable level of camber out on the front to be honest. Then have the toe set near zero, maybe some toe in to help with stability. The car may tramline more with these settings, meaning it will follow the imperfections in the roadway more. It will however push less and turn in better than a factory alignment setting.
    Alexander van Gerbig
    www.europrice.us
    contact@europrice.us
    Follow Europrice on Facebook
    Jan 2009
    Michigan
    Thanks. All that sounds good, but I don't want to screw up the highway manners too much. Do you find those settings fairly livable for day to day use in the R8?
    Supporting Vendor
    Dec 2009
    Oakland, CA
    You should be fine. You can run a little more toe to make it more stable in a straight line, but be aware with more neg camber that can chew up the inside of the tire. If it's not a ton of neg camber and it's less of an issue.
    www.europrice.us
    Jan 2009
    Michigan
    Thanks. I have 4.5mm left on the outside and 5.5 on the inside after 3 track days and 3k road miles. I'd like to improve turn in as much as I can without requiring constant steering on the highway. I figure if I can just adjust enough to even out the wear I'd be happy.
    Senior Member exhilR8's Avatar
    Dec 2010
    NM, USA
    I had my negative camber maxed out, without adding any aftermarket stuff, and they could only get about 0.05 degress extra on the fronts, and about 0.34 extra on the rears. Didn't affect the feel or steering at all, and didn't improve the treadwear on the fronts, only a tiny improvement on the rears.
    2011 R8 5.2 FSI, R-Tronic, Coupe, Ibis White, Carbon fiber sideblade, Carbon fiber inlays, Carbon fiber door sills, Black Interior, Enhanced Leather, Alcantara headliner. Titanium Y-spoke wheels, Glossy Y-spoke wheels, O.Z. Ultraleggera racing wheels, Michelin Pilot Super Sport tires, Dunlop Winter Sport tires, Hoosier R6 racing tires.
    Jan 2009
    Michigan
    Good to know, thanks. I guess I'll just max it out in front. Should the rears be adjusted also?
    Dec 2010
    NM, USA
    Yes, you can just ask the dealer to do a 4-wheel alignment with the maximum negative camber they can get in all 4 wheels. It's not expensive, a couple hundred bucks, tops.
  10. Remove Advertisements
  1. Front Camber Kit Nearly Ready!
    By bz888 in forum Performance Modifications
    Last Post: 02-26-2011, 05:04 PM
  2. Highway RPM's
    By ptaylor_9849 in forum General Discussion
    Last Post: 10-19-2010, 01:41 PM
  3. Camber settings - track
    By yss in forum Performance Modifications
    Last Post: 06-23-2008, 01:46 PM
  4. How will V10 affect V8 prices?
    By pike98 in forum General Discussion
    Last Post: 06-23-2008, 07:38 AM
  5. Honest answer... will this affect resale?
    By jampoTT in forum General Discussion
    Last Post: 07-30-2007, 01:08 AM
