whats the weight of supercharger?of V8 .Stasis or VF engineering, Had anyone weighed it ,i had missed
Doesn't matter![]()
But I could feel the additional weight sitting behind me , Like to maintain The weight balance between Front And Rear axles ,
Trying to reduce weight till now
Quicksilver exhaust could pull down 18 kg
Stasis brakedisc 1kg on each side. Total 2 kg (inclusive of Titanium lugs)
Ppi rear Mag 11 Wheels each 1.5 kg Total 3 kg
Ordered for Ppi Rear Engine Lid with Makrolon Glass reduces weight by 12kg
The total reduction as of now is =30 kg of static weight
Moving weight = 5 kg.
= 35 kg
Wanted to know if I had reduced equivalent weight of supercharger and got back to original sporty Front & Rear weight ratio ?
Well I brought mine over to the UK on a plane and the main unit weighed just over 50lb packed. I suspect it is 20kg or so, but then take off the weight of the OEM manifolds etc. and you probably have an additional 10 -15kg by the time you add in the radiator (in front) and the water tank. Its still lighter than a V10 and faster !![]()
M
The VF and the Stasis are the same piece.
