Is it possible to use the r8 GT programming in a regular R8?
Results 1 to 10 of 14
Thread: Is it possible to use the r8 GT programming in a regular R8?
    SoCal
    Does anyone know if it's possible to use the R8 GT flash/programming in a regular R8? That should give a non r8 GT 560 HP.
    Member Arantor's Avatar
    Jul 2011
    Germany, Frankfurt
    Re: Is it possible to use the r8 GT programming in a regular R8?
    Nop, that's wrong. The GT has an other air-system, so much shorter ways, other pressures through the rear wing and the other designed hood instead of the long way through the sideblades. So you would never get the power of a GT just with flashing the GT-software to a V10. And i guess they have changed some more things besides this.
    LAT
    LAT is offline
    Oct 2010
    Ontario, Canada
    Not clear on what you are describing as other air-system and other pressures
    Levino
    2010 Audi R8 V10 6SPD Phantom Black, MTM tuned, Supersprint exhaust
    1997 C4 Cabriolet, Arctic Silver, Aerokit, RS Tuning cats, 292 PS
    1996 993TT Polar Silver, RS Tuning, 531 PS, 800 NM
    2008 BMW M5 6SPD DD
    Jun 2011
    London, United Kingdom of Great Britain
    the V10 R8 can be remapped to produce 560PS piece of piss
    you just need a good tuner
    Jul 2011
    Germany, Frankfurt
    okay, i'll try again :P
    The Original V8 and V10 has the air-intake for the engine between the sideblades and the door. So when you're driving, the air gets "loaded" through the airstream that's pushed through there. So it is a kind of manifold pressure like it is produced through a charger or turbo.
    The V10 GT has the air-intake in the back of the engine hood, as you can see three intakes there. Through the aerodynamic design of the GT wing, the intake-pressure is a lot higher than by a normal V10/V8 with the sideblade-version. So all together, the GT has shorter ways witch makes it a lot easier for the engine to rev up, and more air-intake-pressure through the aerodynamic wing.
    LAT
    LAT is offline
    Oct 2010
    Ontario, Canada
    thanks, I get what you are saying but,
    Does the Lambo Gallardo not use side intakes to make 560-570 hp
    why would source of air matter as long as desireable a/f ratio is met
    Levino
    2008 BMW M5 6SPD DD
    Jul 2011
    Germany, Frankfurt
    I am not saying it is not possible, just saying with OEM R8 V10 GT software you will not get the GT horsepower out of an normal V10 - that what the threadstarters question was.
    Maybe it is - but for me this is speaking against it
    Jun 2011
    your answer is you can get 560PS from the V10 but not by just flashing the GT map
    take it too an experienced and reputable tuner
    in the UK, MRC Tuning could do it with their eyes closed
    Quote Originally Posted by Alan S View Post
    Yes, as of this date you can increase the power output of a non-GT pre-MY2012 R8 V10 by installing an aftermarket ECU flash. The aftermarket advertises that their programming allows a R8 V10 to equal (or in some cases exceed) the stated power output of the GT. There are a lot of threads about this subject on R8Talk. Caveat Emptor.
    Quote Originally Posted by Arantor View Post
    RIGHT! You cannot simply put the OEM R8 GT programming into a non-GT R8 V10. Other than the obvious logistical reasons (where do you obtain this programmming, and how do you overcome the security in the ECUs and other "systems differences" between the models? The dealer will NOT be able to do this for you!), some of the engine components are upgraded in the GT's V10 over the non-GT V10, so I believe the GT requires its own specific programming.
    Senior Member BlkwdwR8's Avatar
    USA
    Are you saying it's not possible to flash a MY2012 R8 currently? Did something change in 2012 from 2011 in this regard?
  1. GT Tail Light programming
    By KfabR8 in forum Appearance / Body Modifications
    Last Post: 08-16-2011, 05:14 AM
  2. revo + miltek vs regular v8
    By franki68 in forum General Discussion
    Last Post: 04-11-2010, 03:29 PM
  3. revo technik flash programming
    By franki68 in forum Performance Modifications
    Last Post: 09-08-2009, 07:15 PM
  4. Homelink programming
    By B.K. in forum General Discussion
    Last Post: 08-03-2009, 03:09 PM
